nrf52 Radio example read always 0
Im not sure if im doing something wrong or what, but i've been hitting a wall when trying to use the radio example transmitter and receiver.
No matter what i send on the transmitter, the receiver always prints out 0. Here's the code that im using:
Transmitter:
#include <nrf52_radio.h>
nrf52 radio;
void setup() {
  #ifdef DEBUG
    Serial.begin(115200);
  // SETUP RADIO
  radio.init();
void loop()
    radio.write(123);
Receiver:
#include <stdint.h>
#include <stdbool.h>
#include <stdio.h>
nrf52 radio;
void setup() {
  radio.init();
void loop()
  Serial.print("Received packet ");
    uint32_t received = radio.read();
    Serial.print(received);
    Serial.print(" ");
    Serial.print(received, HEX);
    Serial.print(" ");
    Serial.println(received, BIN);
And here's the "library" i made:
#ifndef NRF52_RADIO_H
#define NRF52_RADIO_H
#include <stdint.h>
#ifdef __cplusplus
extern "C" {
#define PACKET_BASE_ADDRESS_LENGTH  (4UL)                   //!< Packet base address length field size in bytes
#define PACKET_STATIC_LENGTH        (1UL)                   //!< Packet static length in bytes
#define PACKET_PAYLOAD_MAXSIZE      (PACKET_STATIC_LENGTH)  //!< Packet payload maximum size in bytes
class nrf52 {
	public:
		nrf52();
		void init();
		uint32_t read();
		void write(uint32_t packet);
	private:
		uint32_t m_packet;
#ifdef __cplusplus
#include "nrf52_radio.h"
#include "nrf.h"
#include "Arduino.h"
#define PACKET_S1_FIELD_SIZE      (0UL)  /**< Packet S1 field size in bits. */
#define PACKET_S0_FIELD_SIZE      (0UL)  /**< Packet S0 field size in bits. */
#define PACKET_LENGTH_FIELD_SIZE  (0UL)  /**< Packet length field size in bits. */
static uint32_t swap_bits(uint32_t inp);
static uint32_t bytewise_bitswap(uint32_t inp);
    uint32_t i;
    uint32_t retval = 0;
    inp = (inp & 0x000000FFUL);
    for (i = 0; i < 8; i++)
        retval |= ((inp >> i) & 0x01) << (7 - i);
    return retval;
      return (swap_bits(inp >> 24) << 24)
           | (swap_bits(inp >> 16) << 16)
           | (swap_bits(inp >> 8) << 8)
           | (swap_bits(inp));
nrf52::nrf52() {}
void nrf52::init() {
	// Enable the High Frequency clock to the system as a whole
	/* Wait for the external oscillator to start up */
	while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) { }
	// Enables the DC/DC converter when the radio is enabled. Need this!
	NRF_POWER->DCDCEN = 0x00000001;
    // Radio config
    NRF_RADIO->TXPOWER   = (RADIO_TXPOWER_TXPOWER_0dBm << RADIO_TXPOWER_TXPOWER_Pos);
    NRF_RADIO->FREQUENCY = 7UL;  // Frequency bin 7, 2407MHz
    NRF_RADIO->MODE      = (RADIO_MODE_MODE_Nrf_1Mbit << RADIO_MODE_MODE_Pos);
    // Radio address config
    NRF_RADIO->PREFIX0 =
        ((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC1) << 8)  // Prefix byte of address 1 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
    NRF_RADIO->PREFIX1 =
        ((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
      | ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
    NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL);  // Base address for prefix 0 converted to nRF24L series format
    NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL);  // Base address for prefix 1-7 converted to nRF24L series format
    NRF_RADIO->TXADDRESS   = 0x00UL;  // Set device address 0 to use when transmitting
    NRF_RADIO->RXADDRESSES = 0x01UL;  // Enable device address 0 to use to select which addresses to receive
    // Packet configuration
    NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE     << RADIO_PCNF0_S1LEN_Pos) |
                       (PACKET_S0_FIELD_SIZE     << RADIO_PCNF0_S0LEN_Pos) |
                       (PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
    NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
                       (RADIO_PCNF1_ENDIAN_Big       << RADIO_PCNF1_ENDIAN_Pos)  |
                       (PACKET_BASE_ADDRESS_LENGTH   << RADIO_PCNF1_BALEN_Pos)   |
                       (PACKET_STATIC_LENGTH         << RADIO_PCNF1_STATLEN_Pos) |
                       (PACKET_PAYLOAD_MAXSIZE       << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
    // CRC Config
    NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
    if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
        NRF_RADIO->CRCINIT = 0xFFFFUL;   // Initial value
        NRF_RADIO->CRCPOLY = 0x11021UL;  // CRC poly: x^16 + x^12^x^5 + 1
    else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
        NRF_RADIO->CRCINIT = 0xFFUL;   // Initial value
        NRF_RADIO->CRCPOLY = 0x107UL;  // CRC poly: x^8 + x^2^x^1 + 1
uint32_t nrf52::read()
	NRF_RADIO->PACKETPTR = (uint32_t)m_packet;
    uint32_t result = 0;
    NRF_RADIO->EVENTS_READY = 0U;
    // Enable radio and wait for ready
    NRF_RADIO->TASKS_RXEN = 1U;
    while (NRF_RADIO->EVENTS_READY == 0U)
        // wait
    NRF_RADIO->EVENTS_END = 0U;
    // Start listening and wait for address received event
    NRF_RADIO->TASKS_START = 1U;
    // Wait for end of packet or buttons state changed
    while (NRF_RADIO->EVENTS_END == 0U)
        // wait
    if (NRF_RADIO->CRCSTATUS == 1U)
        result = m_packet;
    NRF_RADIO->EVENTS_DISABLED = 0U;
    // Disable radio
    NRF_RADIO->TASKS_DISABLE = 1U;
    while (NRF_RADIO->EVENTS_DISABLED == 0U)
        // wait
    return result;
void nrf52::write(uint32_t packet)
	m_packet = packet;
    // send the packet:
    NRF_RADIO->TASKS_TXEN   = 1;
        // wait
        // wait
    // Disable radio
        // wait
