Im not sure if im doing something wrong or what, but i've been hitting a wall when trying to use the radio example transmitter and receiver.
No matter what i send on the transmitter, the receiver always prints out 0. Here's the code that im using:
Transmitter:
#include <nrf52_radio.h>
nrf52 radio;
void setup() {
#ifdef DEBUG
Serial.begin(115200);
// SETUP RADIO
radio.init();
void loop()
radio.write(123);
Receiver:
#include <stdint.h>
#include <stdbool.h>
#include <stdio.h>
nrf52 radio;
void setup() {
radio.init();
void loop()
Serial.print("Received packet ");
uint32_t received = radio.read();
Serial.print(received);
Serial.print(" ");
Serial.print(received, HEX);
Serial.print(" ");
Serial.println(received, BIN);
And here's the "library" i made:
#ifndef NRF52_RADIO_H
#define NRF52_RADIO_H
#include <stdint.h>
#ifdef __cplusplus
extern "C" {
#define PACKET_BASE_ADDRESS_LENGTH (4UL) //!< Packet base address length field size in bytes
#define PACKET_STATIC_LENGTH (1UL) //!< Packet static length in bytes
#define PACKET_PAYLOAD_MAXSIZE (PACKET_STATIC_LENGTH) //!< Packet payload maximum size in bytes
class nrf52 {
public:
nrf52();
void init();
uint32_t read();
void write(uint32_t packet);
private:
uint32_t m_packet;
#ifdef __cplusplus
#include "nrf52_radio.h"
#include "nrf.h"
#include "Arduino.h"
#define PACKET_S1_FIELD_SIZE (0UL) /**< Packet S1 field size in bits. */
#define PACKET_S0_FIELD_SIZE (0UL) /**< Packet S0 field size in bits. */
#define PACKET_LENGTH_FIELD_SIZE (0UL) /**< Packet length field size in bits. */
static uint32_t swap_bits(uint32_t inp);
static uint32_t bytewise_bitswap(uint32_t inp);
uint32_t i;
uint32_t retval = 0;
inp = (inp & 0x000000FFUL);
for (i = 0; i < 8; i++)
retval |= ((inp >> i) & 0x01) << (7 - i);
return retval;
return (swap_bits(inp >> 24) << 24)
| (swap_bits(inp >> 16) << 16)
| (swap_bits(inp >> 8) << 8)
| (swap_bits(inp));
nrf52::nrf52() {}
void nrf52::init() {
// Enable the High Frequency clock to the system as a whole
/* Wait for the external oscillator to start up */
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) { }
// Enables the DC/DC converter when the radio is enabled. Need this!
NRF_POWER->DCDCEN = 0x00000001;
// Radio config
NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_0dBm << RADIO_TXPOWER_TXPOWER_Pos);
NRF_RADIO->FREQUENCY = 7UL; // Frequency bin 7, 2407MHz
NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_1Mbit << RADIO_MODE_MODE_Pos);
// Radio address config
NRF_RADIO->PREFIX0 =
((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
NRF_RADIO->PREFIX1 =
((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
// Packet configuration
NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
(PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
(PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
(PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
(PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
(PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
// CRC Config
NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16 + x^12^x^5 + 1
else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8 + x^2^x^1 + 1
uint32_t nrf52::read()
NRF_RADIO->PACKETPTR = (uint32_t)m_packet;
uint32_t result = 0;
NRF_RADIO->EVENTS_READY = 0U;
// Enable radio and wait for ready
NRF_RADIO->TASKS_RXEN = 1U;
while (NRF_RADIO->EVENTS_READY == 0U)
// wait
NRF_RADIO->EVENTS_END = 0U;
// Start listening and wait for address received event
NRF_RADIO->TASKS_START = 1U;
// Wait for end of packet or buttons state changed
while (NRF_RADIO->EVENTS_END == 0U)
// wait
if (NRF_RADIO->CRCSTATUS == 1U)
result = m_packet;
NRF_RADIO->EVENTS_DISABLED = 0U;
// Disable radio
NRF_RADIO->TASKS_DISABLE = 1U;
while (NRF_RADIO->EVENTS_DISABLED == 0U)
// wait
return result;
void nrf52::write(uint32_t packet)
m_packet = packet;
// send the packet:
NRF_RADIO->TASKS_TXEN = 1;
// wait
// wait
// Disable radio
// wait
