Zigbee coordinator with Xiaomi devices
Hi all!
I found solution for Xiaomi zigbee smart home sensors (gerkon, water sensor, pir motion, and other...) based on CC2530 zigbee shepherd and Trust Center Link Key from lthis ink.
Heve anybody an idea how to implement nrf52840 zigbee light coordinator code to cominicate with Xiaomi devices?
I tried to use it, but i dont inderstand where i have to paste key in source code, when i try to join to network code return  info with unknown signal parameter....
    Have you tried to sniff the Zigbee traffic using this key? I have not looked into the Ziaomi solution, but I guess that if the TC Link Key is available, you should be able to swap the key from one of the examples to connect to them.
    I do not have the sensors to test on, but you can try the example located in nRF5_SDK_for_Thread_and_Zigbee_v1.0.0examples\zigbee\experimental\light_control\light_coordinator
    You can see in the file located in:
    nRF5_SDK_for_Thread_and_Zigbee_v1.0.0\external\zboss\include\zb_config.h
    On line 174, the key is decleared. Try changing it to the key that you found.
    Edvin
  • Yes, i found key, it's the same as in link above!
    I watch console log when gerkon  try to join the network
    There were two statuses
    2 - ZB_ZDO_SIGNAL_DEVICE_ANNCE
    15 - ZB_NWK_SIGNAL_DEVICE_ASSOCIATED
    My Xiaomi device is join the network and i see sniffer data from gerkon to coordinator
    But in console log i dont see any message about data was recieved by coordinator.
    What a handler or function i have to use to watch recieved data from xiaomi device to coordinator?
  • I do not quite understand what you are trying to do.
    You have some products from Xiaomi that uses Zigbee? And they work on their own, is that correct?
    Then you want to use an nRF as a light coordinator in this Zigbee network, is that right? Because then I think you are on the wrong track.
    In a Zigbee network, there is only one coordinator, and only one. If the network already exists, you can not join a network as a coordinator, unless you are the first node/device in the network. I suggest you rather try to join the network as a ligth_switch or light_bulb. I do not know if Xiaomi's solution supports light switches/bulbs, but you can try.
    Edvin
  • no i want to made custom  zigbee gateway for Xiaomi sensors.  I thouth i can do it using coordinator example. My Xiaomi sensor can join the coordinator network. I need to get data from Xiaomi device.
  • Ok, I understand. Are you sure that the Xiaomi devices are not already configured for the Xiamoi coordinator, and hence that they are only looking for that network? They might store network information in an NVMC memory. Or are you sure that there are no other "secret"s that are needed by the devices? Any out of band information that is transferred on commissioning/joining of the network?
    Edvin
