the APP_ERROR in the simple message
I created a simple message mode based on the simple_on_off modle,when I debuged the codes in simple message client,I got an error(app_error),I never changed the codes for this.And there is no trouble when I debugged the simple_on_off modle.Could you tell me some efficacious methods for this problem?
<t: 0>, main.c, 487, ----- BLE Mesh Light Switch Client Demo -----
<t: 0>, nrf_mesh_sdk.c, 187, Initializing softdevice
<t: 0>, nrf_mesh_sdk.c, 122, Initializing SoftDevice...
<t: 2>, nrf_mesh_sdk.c, 131, Ram base: 0x200019C0
<t: 14>, nrf_mesh_sdk.c, 197, Initializing mesh stack
<t: 333>, nrf_mesh_sdk.c, 205, Enabling mesh stack
<t: 337>, main.c, 191, Setting up access layer and models
<t: 356>, nrf_mesh_sdk.c, 72, APP_ERROR: F:\nrf5_SDK_for_Mesh_v1.0.1_src\examples\light_switch\client\src\main.c:212 code 14
Thanks in advance.
  • Hi Zhengrui,
    When you face an error and there is a line of code and code number provided in the log, please check the line of code in the file to see what throws the error and check the error code to see what it means. The error code number is listed in nrf_error.h
  • Thanks for your valuable reply.
    I find the error by following your words.
    #define NRF_ERROR_NULL                        (NRF_ERROR_BASE_NUM + 14) ///< Null Pointer
    But I could not understand the means of the error and I don't know why.Maybe that's the point.I tried my best to solve this problem by myself,but I have to ask for your help after tried many methods.
    Sorry to disturb you again.
  • Please let us know what is the function in that line 212 in main.c, usually in the description of the function you can find why it throw NRF_ERROR_NULL
  • Maybe I know the reason of the error.the codes:
    ERROR_CHECK(simple_message_client_init(&m_clients[i], i));
    and the function is defined as :
    uint32_t simple_message_client_init(simple_message_client_t * p_client, uint16_t element_index)
    if (p_client == NULL ||
    p_client->status_cb == NULL|| p_client->set_cb == NULL)
    return NRF_ERROR_NULL;
    access_model_add_params_t init_params;
    init_params.model_id.model_id = simple_message_CLIENT_MODEL_ID;
    init_params.model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
    init_params.element_index = element_index;
    init_params.p_opcode_handlers = &m_opcode_handlers[0];
    init_params.opcode_count = sizeof(m_opcode_handlers) / sizeof(m_opcode_handlers[0]);
    init_params.p_args = p_client;
    init_params.publish_timeout_cb = NULL;
    return access_model_add(&init_params, &p_client->model_handle);
    /** Forward declaration. */
    typedef struct __simple_message_client simple_message_client_t;
    but I don't understand the mean of the parameters in this function.Did the pointer means the number of the servers?when I debugged I just used one board as the client and there is no server, the error is theNRF_ERROR_NULL,but I don't know which parameter is NULL.
    Could you help me?
    Thanks.
  • Most likely one of this was failed:
    Have you check if all of the above are not NULL when you call the function ?
