NRFX module and NRFX_TWI_DRIVER
Good morning everyone,
I am having a few problems in understanding the new SDK 15.0.0.
First of all, I was unable to find a definition/description of NRFX.....what is it? Is it just a new naming convention, or is it a module doing something specific?
Second thing, assuming it is just a new naming convention, I tried to port my TWI code running smoothly on SDK 14.2 to 15.0.....I can make it work
perfectly if in the sdk_config.h I set both NRFX_TWI_ENABLED (I use both instances 0 and 1) and TWI_ENABLED to 1 (with both instances).
If I only try to enable NRFX_TWI_ENABLED, and I set TWI_ENABLED to 0, then the code does not compile, telling me that instance 0 is undefined....is it normal
or I am doing something wrong?
My whole application include the use of other peripherals and timers, so I would like to understand how to use correctly the NRFX configurations....the release notes only states that this is now used, but I did not understand much more....
Thank you!
