How increase throughput or high data sending rate in BLE mesh sdk using nRF52832 sdk1.0.1?
We have developing solution for IIoT using Nordic BLE mesh technology for many node to other many node then send to own server. We have select one analog sensor and read this adc 3 channels using nRF52832 DK. Each channel of adc data is near about 8KB so total data size is 8*3= 24KB. Now we have successfully send this large amount of data sensor node to relay node.
Simply we are trying to like this:
Sensor Node1,2,3.....N------>Relay Node(use for re-transmit message and expand connectivity range)--------> Server Node(Receive data from relay node and send it to own server using WiFi).
In my server side i have merged  UART example from nRF5 SDK 14.1 into mesh sdk.  Not use mesh serial example in my application. UART example is used because i have interface external WIFI module for internet connectivity to own server.
But now my problem is When i send data Sensor node to relay node it sending very fast it take near about 3 second for sending all data into server.
But when i send this same data relay node to server node(with interface wifi module using UART)at this time it take more time near about 3-4 minutes.
Actually i have enable mesh instaburst feature in my code but not increase throughput.  On this i have few questions as per the following:
  1. Why it only through put low when i send sensor data to server node with merge example is UART?
  2. If i interface UART example into mesh light switch server example node due to this is it affect on throughput?
  3. If yes for increasing this is it have any new configuration for achieving high data rate.
  4. For sending all packets i have use access_model_publish method can you suggest other method for high data rate and also no packet losses between sending..
Thanks in Advanced.......!!!
    I do not want to message to my all group but i want to send message sensor node to relay node to last server node as like. relay node may be increase if we will need to cover large area.
    For this how i can published unicast message to last server and also relaying message with high throughput.
    My sensor data is 24kb analog reading and i able to send this all data to server but throughput is very low with using instabrust feature. How i can increase and it is possible to send this all data to my last server within 2-5 seconds.
    Thanks...!!
  • You can send messages "directly" from sensor node to last server node through the Mesh, independently of what the topology of the network looks like. The relay node functionality is handled by the Mesh stack, and you do not have to do anything in the application for it to relay messages.
    You can use the unicast address to send a message from sensor node to last server node. Messages will automatically propagate from sensor node through relay node to last server node, so you can address last server node directly from sensor node.
    Thanks for answering. Can you please tell me how i can use unicast address in sensor node to publish all messages to my last server. If i have one sensor node and 2 relay node and 1 my last server node.
    Thanks.
  • If you provision & configure the last server node last (i.e. let the client provision the 2 relay nodes first & turn on the last server node at the very end), then you know the last server node will be m_clients[3] because this last server node was provisioned last). I am assuming the sensor node is your client (& provisioner since you are using mesh sdk v1.0.1). Then you can call your modified simple_on_off_client_set() function that sends your data, which then calls send_reliable_message(). This function will send the data via the unicast address to your last server node. Like Martin mentioned, by sending via unicast, you should achieve a higher throughput than sending via the group address.
  • Thanks Bjorn for great answer,
    But If we create 3 server node and one client node all node working fine and cell it to customer. and after few days customer want one more client and server node so how i can add this two node in existing mesh network. Where should i need to change for this extra two node provisioning.
    Thnaks..!!
