How increase throughput or high data sending rate in BLE mesh sdk using nRF52832 sdk1.0.1?
We have developing solution for IIoT using Nordic BLE mesh technology for many node to other many node then send to own server. We have select one analog sensor and read this adc 3 channels using nRF52832 DK. Each channel of adc data is near about 8KB so total data size is 8*3= 24KB. Now we have successfully send this large amount of data sensor node to relay node.
Simply we are trying to like this:
Sensor Node1,2,3.....N------>Relay Node(use for re-transmit message and expand connectivity range)--------> Server Node(Receive data from relay node and send it to own server using WiFi).
In my server side i have merged  UART example from nRF5 SDK 14.1 into mesh sdk.  Not use mesh serial example in my application. UART example is used because i have interface external WIFI module for internet connectivity to own server.
But now my problem is When i send data Sensor node to relay node it sending very fast it take near about 3 second for sending all data into server.
But when i send this same data relay node to server node(with interface wifi module using UART)at this time it take more time near about 3-4 minutes.
Actually i have enable mesh instaburst feature in my code but not increase throughput.  On this i have few questions as per the following:
  1. Why it only through put low when i send sensor data to server node with merge example is UART?
  2. If i interface UART example into mesh light switch server example node due to this is it affect on throughput?
  3. If yes for increasing this is it have any new configuration for achieving high data rate.
  4. For sending all packets i have use access_model_publish method can you suggest other method for high data rate and also no packet losses between sending..
Thanks in Advanced.......!!!
  • You can add the server node by just increasing the SERVER_COUNT by one. That way, the provisioner will keep on trying to provision if the m_configured_devices < SERVER_COUNT (see provisioner_config_successful_cb() in main.c of the light switch client).
    Since the provisioner & client are in the same example for mesh sdk v1, I think it is quite difficult to use multiple clients. I would suggest moving to mesh sdk v2 & making a few small changes in the main.c file of the provisioner:
    In the check_network_state() function in the provisioner, change
    else if (m_nw_state.provisioned_devices == 0) to else if (m_nw_state.provisioned_devices < CLIENT_NODE_COUNT)
    & change:
    else if (m_nw_state.provisioned_devices < SERVER_NODE_COUNT) to else if (m_nw_state.provisioned_devices < CLIENT_NODE_COUNT + SERVER_NODE_COUNT)
    Then, you should be able to provision multiple clients if you set CLIENT_NODE_COUNT > 1. Same as mesh sdk v1, just increase SERVER_NODE_COUNT (or leave it at 30 to keep on provisioning more servers later).
  • Thanks for your response,
    Actually for provisioning multiple client i have created new thread in devlop zone. Right now i am using mesh sdk v2.0.0 and as per your answer above i have changed in my program main file but only one client is provisioned i have set CLIENT_NODE_COUNT  2 but other client is not provisioning. All server is provisioned not problem.
    After changed in  provisioner_config_successful_cb  the logs as per the following:
    <t: 0>, main.c, 551, ----- BLE Mesh Light Switch Provisioner Demo -----
    <t: 0>, mesh_softdevice_init.c, 112, Initializing SoftDevice...
    <t: 0>, mesh_softdevice_init.c, 77, Enabling BLE...
    <t: 2>, mesh_softdevice_init.c, 88, Ram base: 0x200032C8
    <t: 627>, main.c, 489, Initializing and adding models
    <t: 638>, main.c, 532, Setup defaults: Adding keys, addresses, and bindings
    <t: 823>, provisioner_helper.c, 329, netkey_handle: 0
    <t: 836>, main.c, 579, <start>
    <t: 27408>, main.c, 118, Flash write complete
    <t: 27410>, main.c, 566, Starting application ...
    <t: 27413>, main.c, 568, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100
    <t: 27417>, main.c, 569, Dev key : 30300BE2AB392FD8C0D3E1EDA260F2C0
    <t: 27419>, main.c, 570, Net key : 1614B29395D562E459B33F194AFC601E
    <t: 27423>, main.c, 571, App key : 1D0F81F728CA562339AC0820DE30BC0E
    <t: 27425>, main.c, 572, Press Button 1 to start provisioning and configuration process.
    <t: 216476>, main.c, 449, Button 1 pressed
    <t: 216478>, main.c, 362, Waiting for Client node to be provisioned ...
    <t: 221244>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
    <t: 221249>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 221252>, provisioner_helper.c, 95, UUID filter matched
    <t: 221648>, provisioner_helper.c, 259, Provisioning link established
    <t: 301050>, provisioner_helper.c, 254, Static authentication data provided
    <t: 312309>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 3 remaining retries: 2
    <t: 312314>, provisioner_helper.c, 160, Provisioning failed. Retrying...
    <t: 314315>, provisioner_helper.c, 144, UUID seen: 0059FFFF000000001967BC1B8F0FA045
    <t: 319958>, provisioner_helper.c, 144, UUID seen: 0059FFFF00000000799C40D7D0823B74
    <t: 357737>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 357740>, provisioner_helper.c, 95, UUID filter matched
    <t: 358404>, provisioner_helper.c, 259, Provisioning link established
    <t: 436534>, provisioner_helper.c, 254, Static authentication data provided
    <t: 448962>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 3 remaining retries: 1
    <t: 448966>, provisioner_helper.c, 160, Provisioning failed. Retrying...
    <t: 451451>, provisioner_helper.c, 144, UUID seen: 0059FFFF00000000799C40D7D0823B74
    <t: 491519>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 491523>, provisioner_helper.c, 95, UUID filter matched
    <t: 491852>, provisioner_helper.c, 259, Provisioning link established
    <t: 504728>, provisioner_helper.c, 254, Static authentication data provided
    <t: 516812>, provisioner_helper.c, 192, Provisioning completed received
    <t: 516814>, provisioner_helper.c, 197, Adding device address, and device keys
    <t: 516820>, provisioner_helper.c, 214, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    <t: 520187>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 0
    <t: 520192>, main.c, 283, Provisioning successful
    <t: 520194>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x0100 elements: 5
    <t: 520197>, node_setup.c, 672, Configuring Node: 0x0100
    <t: 520201>, node_setup.c, 586, Config client setup: devkey_handle:2 addr_handle:0
    <t: 520204>, node_setup.c, 361, Getting composition data
    <t: 520267>, main.c, 118, Flash write complete
    <t: 570607>, main.c, 333, Config client event
    <t: 570609>, node_setup.c, 371, Adding appkey
    <t: 571424>, main.c, 333, Config client event
    <t: 571426>, node_setup.c, 272, opcode status field: 0
    <t: 571429>, node_setup.c, 382, App key bind: Health server
    <t: 572075>, main.c, 333, Config client event
    <t: 572077>, node_setup.c, 272, opcode status field: 0
    <t: 572080>, node_setup.c, 450, Setting publication address for the health server to 0x0001
    <t: 572895>, main.c, 333, Config client event
    <t: 572897>, node_setup.c, 272, opcode status field: 0
    <t: 572899>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0101
    <t: 573693>, main.c, 333, Config client event
    <t: 573695>, node_setup.c, 272, opcode status field: 0
    <t: 573698>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0102
    <t: 574580>, main.c, 333, Config client event
    <t: 574582>, node_setup.c, 272, opcode status field: 0
    <t: 574584>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0103
    <t: 575379>, main.c, 333, Config client event
    <t: 575381>, node_setup.c, 272, opcode status field: 0
    <t: 575384>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0104
    <t: 576213>, main.c, 333, Config client event
    <t: 576215>, node_setup.c, 272, opcode status field: 0
    <t: 576218>, node_setup.c, 301, Set: on/off client: 0x0101 pub addr: 0x0105
    <t: 577119>, main.c, 333, Config client event
    <t: 577121>, node_setup.c, 272, opcode status field: 0
    <t: 577124>, node_setup.c, 301, Set: on/off client: 0x0102 pub addr: 0x0106
    <t: 578014>, main.c, 333, Config client event
    <t: 578016>, node_setup.c, 272, opcode status field: 0
    <t: 578019>, node_setup.c, 301, Set: on/off client: 0x0103 pub addr: 0xCAFE
    <t: 578946>, main.c, 333, Config client event
    <t: 578949>, node_setup.c, 272, opcode status field: 0
    <t: 578951>, node_setup.c, 301, Set: on/off client: 0x0104 pub addr: 0xCAFE
    <t: 580617>, main.c, 333, Config client event
    <t: 580619>, node_setup.c, 272, opcode status field: 0
    <t: 580622>, main.c, 249, Configuration of device 0 successful
    <t: 580625>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
    <t: 580682>, main.c, 118, Flash write complete
    <t: 583057>, provisioner_helper.c, 144, UUID seen: 0059FFFF00000000799C40D7D0823B74
    <t: 583060>, provisioner_helper.c, 95, UUID filter matched
    <t: 583652>, provisioner_helper.c, 259, Provisioning link established
    <t: 596413>, provisioner_helper.c, 254, Static authentication data provided
    <t: 608094>, provisioner_helper.c, 192, Provisioning completed received
    <t: 608097>, provisioner_helper.c, 197, Adding device address, and device keys
    <t: 608102>, provisioner_helper.c, 214, Addr: 0x0105 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
    <t: 611926>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2
    <t: 611930>, main.c, 283, Provisioning successful
    <t: 611932>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x0105 elements: 1
    <t: 611936>, node_setup.c, 672, Configuring Node: 0x0105
    <t: 611939>, node_setup.c, 586, Config client setup: devkey_handle:3 addr_handle:1
    <t: 611942>, node_setup.c, 361, Getting composition data
    <t: 612007>, main.c, 118, Flash write complete
    <t: 661973>, main.c, 333, Config client event
    <t: 661976>, node_setup.c, 371, Adding appkey
    <t: 662898>, main.c, 333, Config client event
    <t: 662900>, node_setup.c, 272, opcode status field: 0
    <t: 662903>, node_setup.c, 382, App key bind: Health server
    <t: 664244>, main.c, 333, Config client event
    <t: 664246>, node_setup.c, 272, opcode status field: 0
    <t: 664248>, node_setup.c, 397, App key bind: Simple On/Off server
    <t: 664910>, main.c, 333, Config client event
    <t: 664912>, node_setup.c, 272, opcode status field: 0
    <t: 664915>, node_setup.c, 450, Setting publication address for the health server to 0x0001
    <t: 665849>, main.c, 333, Config client event
    <t: 665852>, node_setup.c, 272, opcode status field: 0
    <t: 665854>, node_setup.c, 476, Set: on/off server pub addr: 0x0101
    <t: 666827>, main.c, 333, Config client event
    <t: 666830>, node_setup.c, 272, opcode status field: 0
    <t: 666832>, node_setup.c, 487, Adding subscription
    <t: 667623>, main.c, 333, Config client event
    <t: 667625>, node_setup.c, 272, opcode status field: 0
    <t: 667627>, main.c, 249, Configuration of device 1 successful
    <t: 667630>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
    <t: 667687>, main.c, 118, Flash write complete
    <t: 708783>, provisioner_helper.c, 144, UUID seen: 0059FFFF000000001967BC1B8F0FA045
    <t: 708786>, provisioner_helper.c, 95, UUID filter matched
    <t: 709091>, provisioner_helper.c, 259, Provisioning link established
    <t: 722488>, provisioner_helper.c, 254, Static authentication data provided
    <t: 734332>, provisioner_helper.c, 192, Provisioning completed received
    <t: 734335>, provisioner_helper.c, 197, Adding device address, and device keys
    <t: 734340>, provisioner_helper.c, 214, Addr: 0x0106 addr_handle: 2 netkey_handle: 0 devkey_handle: 4
    <t: 738288>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2
    <t: 738293>, main.c, 283, Provisioning successful
    <t: 738295>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x0106 elements: 1
    <t: 738299>, node_setup.c, 672, Configuring Node: 0x0106
    <t: 738302>, node_setup.c, 586, Config client setup: devkey_handle:4 addr_handle:2
    <t: 738305>, node_setup.c, 361, Getting composition data
    <t: 738369>, main.c, 118, Flash write complete
    <t: 788787>, main.c, 333, Config client event
    <t: 788790>, node_setup.c, 371, Adding appkey
    <t: 789524>, main.c, 333, Config client event
    <t: 789526>, node_setup.c, 272, opcode status field: 0
    <t: 789529>, node_setup.c, 382, App key bind: Health server
    <t: 816563>, main.c, 333, Config client event
    <t: 816565>, node_setup.c, 272, opcode status field: 0
    <t: 816568>, node_setup.c, 397, App key bind: Simple On/Off server
    <t: 818112>, main.c, 333, Config client event
    <t: 818115>, node_setup.c, 272, opcode status field: 0
    <t: 818117>, node_setup.c, 450, Setting publication address for the health server to 0x0001
    <t: 818985>, main.c, 333, Config client event
    <t: 818988>, node_setup.c, 272, opcode status field: 0
    <t: 818990>, node_setup.c, 476, Set: on/off server pub addr: 0x0102
    <t: 847852>, main.c, 333, Config client event
    <t: 847854>, node_setup.c, 272, opcode status field: 0
    <t: 847857>, node_setup.c, 487, Adding subscription
    <t: 849226>, main.c, 333, Config client event
    <t: 849228>, node_setup.c, 272, opcode status field: 0
    <t: 849230>, main.c, 249, Configuration of device 2 successful
    <t: 849233>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
    <t: 849290>, main.c, 118, Flash write complete
    <t: 854734>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 885310>, main.c, 333, Config client event
    <t: 900819>, main.c, 312, Node 0x0100 alive with 0 active fault(s), RSSI: -59
    <t: 920267>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 985847>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 993344>, main.c, 312, Node 0x0105 alive with 0 active fault(s), RSSI: -39
    <t: 1051573>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1117284>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1146584>, main.c, 312, Node 0x0106 alive with 0 active fault(s), RSSI: -52
    <t: 1183096>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1228689>, main.c, 312, Node 0x0100 alive with 0 active fault(s), RSSI: -52
    <t: 1248929>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1314728>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1320740>, main.c, 312, Node 0x0105 alive with 0 active fault(s), RSSI: -43
    <t: 1380526>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1446203>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 1474202>, main.c, 312, Node 0x0106 alive with 0 active fault(s), RSSI: -59
    We are stuck for provisioning multiple client by last 5 days until not get solution.
    For the same i have created new thread in dev. zone will you continue here
    Thanks.
