Light Switch example communication from server to client
Dear all,
   I have two nRF52 Preview DK boards with the SoC nRF52840. I am testing the light switch example on both boards. I have changed the light_switch_server, such that after pressing "Button1" the server send a message to the client, unfortunately this simple test doesn´t work. First of all, it is possible to do that? On the simple_on_off_server.c i have created a function "publish_state2", this is equal to the function "publish_state", but has a different opcode, please see below the code. The function publish_state2 is called after "Button1" is pressed and if the device is provisioned.
void publish_state2(simple_on_off_server_t * p_server, bool value)
    simple_on_off_msg_status_t status;
    status.present_on_off = value ? 1 : 0;
    access_message_tx_t msg;
    msg.opcode.opcode = SIMPLE_ON_OFF_OPCODE_DATA;
    msg.opcode.company_id = ACCESS_COMPANY_ID_NORDIC;
    msg.p_buffer = (const uint8_t *) &status;
    msg.length = sizeof(status);
    (void) access_model_publish(p_server->model_handle, &msg);
/** Simple OnOff opcodes. */
typedef enum
    SIMPLE_ON_OFF_OPCODE_SET = 0xC1,            /**< Simple OnOff Set. */
    SIMPLE_ON_OFF_OPCODE_GET = 0xC2,            /**< Simple OnOff Get. */
    SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE = 0xC3, /**< Simple OnOff Set Unreliable. */
    SIMPLE_ON_OFF_OPCODE_STATUS = 0xC4,          /**< Simple OnOff Status. */
    SIMPLE_ON_OFF_OPCODE_DATA = 0xC5
} simple_on_off_opcode_t;
In the client side i have created a new opcode handler, please see the code below.
static const access_opcode_handler_t m_opcode_handlers[] =
    {{SIMPLE_ON_OFF_OPCODE_STATUS, ACCESS_COMPANY_ID_NORDIC}, handle_status_cb},
    {{SIMPLE_ON_OFF_OPCODE_DATA, SIMPLE_ON_OFF_OPCODE_DATA}, handle_data_cb}
static void handle_data_cb(access_model_handle_t handle, const access_message_rx_t * p_message, void * p_args)
  data_received=true;
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data received");
  hal_led_pin_set(14,true);
  hal_led_pin_set(15,true);
Based on the light switch example i also have the following questions?
- The light switch client implements one model for each switch server. So, a network composed by one gateway (provisioner) and many end-devices (in the order of hundreds), the gateway receives and send data to the end-devices, this gateway should implement one model for each end-device?
- The light switch servers can communicate between them?
Rafael Santos Costa
