How to start the timer in counter mode in nrf52 and how to count the number of pulses received in a pin ?
Thank you
Thank you
You should look into the PPI.
Here is an example, which uses the PPI. It uses a timer to toggle a GPIO, but you can change the GPIO to "event" instead of "task", and use the timer in counter mode. The timer can be configured something like this:
void timer_init()
NRF_TIMER3->BITMODE = TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos;
NRF_TIMER3->PRESCALER = 0;
NRF_TIMER3->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk << TIMER_RELOAD_CC_NUM;
NRF_TIMER3->MODE = TIMER_MODE_MODE_Counter << TIMER_MODE_MODE_Pos;
NRF_TIMER3->CC[TIMER_RELOAD_CC_NUM] = TIMER_RELOAD;
Then you need to start the timer with:
NRF3_TIMER3->TASKS_START = 1;
Then configure the GPIO like in the example, and set a PPI channel something like the following:
NRF_PPI->CH[PPI_CH_1].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[GPIOTE_CH];
NRF_PPI->CH[PPI_CH_1].TEP = (uint32_t)&NRF_TIMER3->TASKS_COUNT;
Then you can get the count value by checking the timer value:
NRF_TIMER3->TASKS_CAPTURE[0];
and check the value with:
uint32_t value = NRF_TIMER3->CC[0];
you can also reset the counter using:
NRF_TIMER3->TASKS_CLEAR;
I have not tested this right now, so the calls are from my memory, but it should look something like this.
Edvin
