PWM driver accuracy
Hello everyone
first if all, im not an expert in PWM, but doing my best to understand everything
I have successfully created and tested a project using the pwm_driver example.
 nrf_drv_pwm_config_t const config0 =
        .output_pins =
            OUTPUT_PIN_1 | NRF_DRV_PWM_PIN_INVERTED,             // channel 0
            OUTPUT_PIN_2 | NRF_DRV_PWM_PIN_INVERTED,             // channel 1
            OUTPUT_PIN_3 | NRF_DRV_PWM_PIN_INVERTED,             // channel 2
            NRF_DRV_PWM_PIN_NOT_USED                             // channel 3
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_1MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = 100,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
in this piece of code, the top value is set to 100.
I understand that I have an accuracy of 0 to 100, so its actually just a percentage
Now i would like to have an accuracy of 0 to 65535 ( actually just a 16-bit integer )
I have already tried playing around with the top value but it seems to only go around 30 000.
I have been looking around and my guess is that I have to change the base_clock, but i don't really know what I'm doing at ths point.
Is this even possible to achieve? If not, whats the maximum top value then?
Thanks in advance
Maxime Mylle
