SAADC reinit crash device
Hi
I am running saadc battery measurement using the refernce code.
When I run the  adc_configure() I have about 500uA consumption
then According to this thread   I run this code (below 3 lines)  after I read the battery level in the saadc_event_handler()
nrf_drv_saadc_uninit();
NRF_SAADC->INTENCLR = (SAADC_INTENCLR_END_Clear << SAADC_INTENCLR_END_Pos);
NVIC_ClearPendingIRQ(SAADC_IRQn);
The problem occuers when I try to re-start the measument again, the device crash if I run adc_configure() or even just run nrf_drv_saadc_init()
Any advice?  why does this occuer?
void adc_configure(void)
ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
nrf_saadc_channel_config_t config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
err_code = nrf_drv_saadc_channel_init(0, &config);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
//reduce 500uA from saadc currents
// nrf_drv_saadc_uninit();
// NRF_SAADC->INTENCLR = (SAADC_INTENCLR_END_Clear << SAADC_INTENCLR_END_Pos);
//NVIC_ClearPendingIRQ(SAADC_IRQn);
  • Hey Yaniv,
    You need to uninit the driver after the ADC is finished sampling, in the event handler and not in the adc_configure function.
    Cheers,
    Håkon.
    I am doing that, Sorry didn't copy that part
    still crashing after second init (not after uinint)
    Any advice?
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
    nrf_saadc_value_t adc_result;
    uint16_t batt_lvl_in_milli_volts;
    uint8_t percentage_batt_lvl;
    uint32_t err_code;
    adc_result = p_event->data.done.p_buffer[0];
    err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
    batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
    DIODE_FWD_VOLT_DROP_MILLIVOLTS;
    percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
    if (batt_lvl_in_milli_volts > 0x0C40) //> 2.9V
    batt_lvl_in_milli_volts2 = 0x30;
    if (batt_lvl_in_milli_volts < 0x0C40) //2.5V
    batt_lvl_in_milli_volts2 = 0x25;
    if (batt_lvl_in_milli_volts < 0x0834) //<2.1V
    batt_lvl_in_milli_volts2 = 0x20;
  • I'll test your code when I get back to work on Wednesday.
