Notification length greater than current connection MTU size (not MTU max size)
Hey Guys,
Have been playing around with various MTU sizes to better understand throughput.  I'm curious about one scenario though.  Let's say for example that we are using the UART service and our MAX_MTU size is 158.  The UART service sets the characteristic to use a max length of MAX_MTU.
Then let's say in my code I do ble_nus_string_send(&m_nus, data, dataLength), where dataLength = 100.
For phones capable of higher MTUs & DLE this will work fine and we'll get higher throughput.  However, what happens if a older phone who is only capable of an MTU size of 23 connects?
I've tested this on my phone by connecting and then manually setting the MTU connection size to 23.  It looks like my code doesn't throw an errors, I still see TX complete events.  However, in nrfConnect, I don't see any data being read back.
What is the expected behavior here?  Or is it expected that I need to keep track of the MTU size and adjust the notification length appropriately?
    Bluetooth Specification Version 5.0 | Vol 3, Part F,  3.4.7.1 Handle Value Notification has this to say about notifications:
    "If the attribute value is longer than (ATT_MTU-3) octets, then only the first (ATT_MTU-3) octets of this attributes value can be sent in a notification"
    A workaround is to implement a mechanism that splits the characteristic value into several ATT_MTU-3 bytes long pieces and send them using multiple notifications. The offset field in the ble_gatts_hvx_params_t structure comes in handy here.
  • Hi ,
    Thanks for the tip.  Does this mean that the SDK will truncate data and then send it through?  Or will it just error out?  Or will there be unexpected behaviour?
    As I mentioned it seems like I'm still getting TX complete events but I'm not seeing any data on the TX characteristic on nrfConnect when I would otherwise.
    It should just truncate the data. However, this is the definition of the function you reference in the OP:
    uint32_t ble_nus_string_send(ble_nus_t * p_nus, uint8_t * p_string, uint16_t * p_length)
        ble_gatts_hvx_params_t hvx_params;
        VERIFY_PARAM_NOT_NULL(p_nus);
        if ((p_nus->conn_handle == BLE_CONN_HANDLE_INVALID) || (!p_nus->is_notification_enabled))
        if (*p_length > BLE_NUS_MAX_DATA_LEN)
            return NRF_ERROR_INVALID_PARAM;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_nus->tx_handles.value_handle;
        hvx_params.p_data = p_string;
        hvx_params.p_len  = p_length;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        return sd_ble_gatts_hvx(p_nus->conn_handle, &hvx_params);
    You can see there is an if (*p_length > BLE_NUS_MAX_DATA_LEN) statement. Could this be the reason why nothing is sent? Are you checking the return codes of ble_nus_string_send()?
  • Yup I've made sure that BLE_NUS_MAX_DATA_LEN is equal to or greater than the notification length I'm trying to send out.  In my case NRF_SDH_BLE_GATT_MAX_MTU_SIZE is defined as 115 and I'm sending 100 bytes out with the notification call.
    I'm not getting any errors, as I'm seeing a TX complete event.  I wonder if this is something on the nrfConnect side.
    This isn't too important anyway...truncated data would be bad regardless so it's clear I need to keep track of the MTU size for that connection and handle appropriately.
  • What nRF Connect software are you using? For mobile or PC? I tried both and it seems to work. The peripheral and central negotiate an MTU of 64 bytes and when I tried to notify 64++ bytes from the peripheral I can see that only 64 bytes are received on the central. I tried both nRF Connect for PC and Android.
    I have attached the code I used for testing. I used SDK 14.2.0 and S132 v5.0.0.
    205956-mtu-hvn-length.7z
  • Odd.  I was testing with nrfConnect for mobile (Android Pixel 2).  Note that I'm using SDK v14.0.0 and S132 v5.0.0.
    I'll take another closer look when I get a chance (and also at your example code), but at least I know the expected behaviour now.  I'll mark your reply as answer and move on.  Thanks!
