error code 0x057D
hi
I am using nRF52832.i have added 3 service and and 3 characterastics to one service
1.Peripheral service (accelormeter + gyroscope sensor) and 3 characterstics
2.battery service
3 device information service
i am using SDK14.2.0
 i connect to device and disconnect using nRF connect app,when i try to reconnect ,i cant be reconnected until i dont reprogram the device.I run code in debug mode
i found this 0> <error> app: Error 0x057D (1405) at line 1024 in file: KGJ`hóˆ@h
though i havent added file name with this "KGJ`hóˆ@h".I am not able to understand why device cant be reconnected and error with this file name and code .
quick  response will be highly  appreciated .
Thank you
  • I placed the APP_ERROR_CHECK(1); into my main.c and it worked as intended. The line number and file correctly matched where it was placed. Are there any other suggestions?
  • Sorry. I realize I wasn't as clear as I intended.
    Define DEBUG in your preprocessor defines, turn off optimization, and set a breakpoint on line 73 in app_error.c.
    If it stops there, you should be able to add error_info to watch, and what APP_ERROR_CHECK() that received the err_code != 0.
    The reason to add APP_ERROR_CHECK(1) was just to see that you found the right place (73 in app_error.c).
    (screenshot from APP_ERROR_CHECK(1) in main() function)
    Set a breakpoint here, remove APP_ERROR_CHECK(1), and see if you can get any more sensible data from the weird error log.
    Edvin
