error code 0x057D
hi
I am using nRF52832.i have added 3 service and and 3 characterastics to one service
1.Peripheral service (accelormeter + gyroscope sensor) and 3 characterstics
2.battery service
3 device information service
i am using SDK14.2.0
 i connect to device and disconnect using nRF connect app,when i try to reconnect ,i cant be reconnected until i dont reprogram the device.I run code in debug mode
i found this 0> <error> app: Error 0x057D (1405) at line 1024 in file: KGJ`hóˆ@h
though i havent added file name with this "KGJ`hóˆ@h".I am not able to understand why device cant be reconnected and error with this file name and code .
quick  response will be highly  appreciated .
Thank you
    That is strange. Can you please try to enable debug mode (define "DEBUG" in your preprocessor defines) and set a breakpoint at line in app_error.c and see if it stops? Then check the file name on the file that caused the error? You probably also need to set the optimization level to 0 (-O0) in your project settings.
    Edvin
  • i have set optimization level 0(-O0) and c/c++ define preprocessor output
    BOARD_PCA10040 CONFIG_GPIO_AS_PINRESET FLOAT_ABI_HARD NRF52 NRF52832_XXAA NRF52_PAN_74 NRF_SD_BLE_API_VERSION=5 S132 SOFTDEVICE_PRESENT SWI_DISABLE0 DEBUG MPU9255 MPU_USES_TWI
    i set breakpoint at line 73 of function  app_error_handler() of app_error.c .It doesnot stop to breakpoint .
  • Sorry. I forgot to insert the line number, but you are correct. I meant to say line 73.
    Does it stop there if you try to enter:
    APP_ERROR_CHECK(1); somewhere in the start of your main() function?
    Just to check that the error handler is set up correctly. I do not understand completely what is printed in the log. Of course, there is something weird with the name, but the error code, 0x057D also seems unknown.
    Edvin
  • Has anyone solved this? I am seeing the exact same issue. Usually happens upon a reconnection. If I perform several disconnections followed by reconnections, it will eventually get into this state.
  • Do you get the exact same message, or something similar?
    Can you also try to add an APP_ERROR_CHECK(1); somewhere in your main() function, and figure out where in the project that tells you what APP_ERROR_CHECK(err_code) that is caught in the error handler.
    The reason I can't tell you exactly where is because the error handler works a bit different in different IDEs.
    The jibberish message can have a couple of reasons:
    1. There is something wrong with the LOG when the error occurs, so that the message looks weird.
    2. The error log doesn't understand what function that returned the err_code passed into APP_ERROR_CHECK, and it is having difficulties to translate it to readable text.
    Edvin
