nrfjprog not connecting to nrf51822
Hello All,
I was doing some development on the Nordic nrf51822 and it was working fine without any issues.
I tried to remove some functions from the main loop (not removing the softdevice), and then I was able to flash it to the nrf51822 and afterwards I wasn't able to connect to the board. I am always getting the following failure when I try to flash using the nrfjprog:
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
and when I check the log, this is what I see:
nrfjprog --program DeploymentSet/FINAL.hex -f nrf51 --chiperase --log
nrfjprog verion 9.7.2
FUNCTION: open_dll.
FUNCTION: open_dll.
FUNCTION: enum_emu_snr.
FUNCTION: connect_to_emu_with_snr.
FUNCTION: connect_to_emu_without_snr.
Device "NRF51822_XXAA" selected.
FUNCTION: read_device_version.
Found SW-DP with ID 0x0BB11477
Scanning AP map to find all available APs
AP[1]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x04770021)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xF0000000
CPUID register: 0x410CC200. Implementer code: 0x41 (ARM)
Found Cortex-M0 r0p0, Little endian.
FPUnit: 0 code (BP) slots and 0 literal slots
CoreSight components:
ROMTbl[0] @ F0000000
JLinkARM.dll ReadMemU32 returned error -1.
FUNCTION: close_dll.
So, I want to understand what is wrong with the connection, knowing that it was working fine an hour ago?
Thank you!
