multilink db discovery gives discovery response multiple times for 1st ble connection after reset.
hi,
i am doing a project where i have to discover custom services on connected ble nodes.
i am using nrf52832 as central device and thingy 52 as peripheral device i have used sdk 14.2.0 multilink central example and modified it to discover all custom services.
so far i am able to discover all custom services if value of "NRF_SDH_BLE_CENTRAL_LINK_COUNT" is 1.but when i changed it's value to more then 1(i have used 2,4,8) i am getting these massages of system fault on uart terminal
<error> app: Fatal error
<warning> app: System reset
when debug and put uart output on terminal  with original example i figured that on first connection after program starts service discovery response event is generated same number of times as NRF_SDH_BLE_CENTRAL_LINK_COUNT and that causes above error.
is there any way to stop  multiple discovery event for first connection after reset.
thanks
  • Hi Nikunj,
    Could you point to the exact place that the error was thrown ?  Which function ?
    Do you have the same issue when you test with 2 peripheral + 1 central running lbs service ?
  • hi hung bui,
    so i am getting error code 0x00000011 by calling api "sd_ble_gattc_read" to read full 128-bit base uuid.
    basically i am doing full db discovery by providing argument ble_uuid_t const *p_srvc_uuid = NULL in sd_ble_gattc_primary_services_discover API.
    but my question is that why i am getting number of  BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event same as number of NRF_SDH_BLE_CENTRAL_LINK_COUNT.
    so in default ble_central_multilink example NRF_SDH_BLE_CENTRAL_LINK_COUNT is 8 so i am getting BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event 8 times.
    but if BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP is 1 my program works fine.
     is there any way to reduce BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP to 1
    thanks
  • Error code 0x11 (17 decimal = NRF_ERROR_BUSY) with sd_ble_gattc_read() telling that there is other client process underway.
    Note that for every central link you have, there will be a lbs client being created. Are you sure you are not calling ble_db_discovery_start() for all of the clients you have, regardless how many connection you actually have ?
    Do you see the same error when you test with unmodified multilink central example ?
  • hi,
    i have 8 connections,
    but i am sure i am only starting ble_db_discovery_start for connection handle 0 only.
    when i put a nrf log info in BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP and commented other process.
    i got this response on terminal
    info> app: Multilink example started.
    <info> app: Start scanning for device name Thingy.
    <info> app: Connection 0x0 established, starting DB discovery.
    <info> ble_db_disc: connection handle 0 service found 0x1800
    when i connected 4 nodes following response i got
    <info> app: Connection 0x3 established, starting DB discovery.
    <info> ble_db_disc: connection handle 1 service found 0x1800
    <info> ble_db_disc: connection handle 2 service found 0x1800
    <info> ble_db_disc: connection handle 3 service found 0x1800
    when i connected 8 nodes i got following response
    <info> app: Connection 0x7 established, starting DB discovery.
    <info> ble_db_disc: connection handle 4 service found 0x1800
    <info> ble_db_disc: connection handle 5 service found 0x1800
    <info> ble_db_disc: connection handle 6 service found 0x1800
    <info> ble_db_disc: connection handle 7 service found 0x1800
    please tell me what is happening here. either way i am getting 8 times response
    is this problem with softdevice or my code.?
  • Please answer my question, do you see the same problem when testing with the stock example ?
