It couldn't startup application after move application from region2 to region1
Hi all,
I try to create a new project to update my firmware using twi(I2C) interface.
In my test case, first i download firmware to region2 via keil, then copy the firmware from region2 to region1, but after erase region2, it couldn't startup.
If i don't erase region2, application could startup success.
Any suggestions or pointers are very much appreciated. Thanks.
  • Hi Kevin,
    How do you do DFU update ? Do you have a bootloader ? Do you use our bootloader ?
    How do you start your application at region 2 ? Do you have any kind of vector table forwarding ? Do you use our softdevice ?
  • Hi Hung Bui,
    I used the SDK12.2(52832), and modify the example Nordic 52832\nRF5_SDK_12.2.0_f012efa\examples\dfu\bootloader_secure.
    I remove the ble dfu and firmware check function, only save boot function.
    This is my test step:
    1. Erase region 1
    2. Copy region 2 to region 1
    3. Erase region 2
    In this case, it could not startup success. If do not to do setp 3, it will startup success.
    And I found some difference if changed keil download address and build it, the build hex file will difference.
    So I want to build a firmware that the download address is region 1 but download the firmware to region 2 address.
    Is there another(not keil or nRFgo studio) way can I download the appilcation(build address is region 1) to region 2 address?
    Thanks!!
