Allowing connections, then switching to connection-less.
I need to allow BLE connections for a period of time after restart, then prevent connections (unless a button is pressed).  Is this functionality as simple as re-configuring the advertising parameters to use (  BLE_GAP_ADV_TYPE_ADV_NONCONN_IND ).
Also, I am using scan responses.  Do I need to use BLE_GAP_ADV_TYPE_ADV_NONCONN_IND instead, and will this prevent connections.  I've seen it mentioned in other forum threads but the documentation is not clear whether this allows connections or not.
Is there anything else I need to do to start preventing connections in the code.
    To allow a scanner (central) to read your scan response, but not connect, you should use BLE_GAP_ADV_TYPE_ADV_SCAN_IND. I agree that the documentation of these defines are sparse, but if you search for ADV_SCAN_IND in the Bluetooth Core specification you will find the information you need.
    If you use ADV_NONCONN_IND the scanner will neither be able to read your scan response nor connect.
  • Thanks.  Is there an API to configure the type.  I didn't see one.  If not, what is the best way to configure this so that I can switch between types?
  • Yes, but what it looks like depends on what SDK you use.
    If you look at the beacon example in SDK 15 for example, it is configured like this:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
    m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration = 0; // Never time out.
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    You can see that in SDK 15 BLE_GAP_ADV_TYPE_ADV_SCAN_IND has been renamed to BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED.
