How to make sec_info_request_process with p_existing_key->enc_info.lesc == true?
    I found my host device(non-Nordic) keeps sending a fix EDIV for all the client device. It seems working fine with other device, but not Nordic. I found Nordic stack return errors in sec_info_request_process(). The error is happened on line 370. This makes p_nec_info == NULL. The if statement checks either p_existing_key->enc_info.lesc is true or EDIV matches. How can I make the first condition true? Currently, the flag is always false. Anything I can tweak on the host side to make this work?
            if (   p_existing_key->enc_info.lesc               <--------- how to make this true?
                || (im_master_ids_compare(&p_existing_key->master_id,
                                          &p_gap_evt->params.sec_info_request.master_id)))
                p_enc_info = &p_existing_key->enc_info;
Thank you,
Min-Ching
