Advertising interval from Slow to fast without init process
I am implementing a beacon solution and intrested to move from fast to slow and vis versa(slow to fast) advertising modes -
i.e. BLE_ADV_MODE_FAST & BLE_ADV_MODE_SLOW
This is a coincell powered device and the goal for these transitions is to save battery.
I am using nRF5_SDK_14.2.
In this SDK version is there a way to move from SLOW to Fast without running again advertising_init()?
Related post https://devzone.nordicsemi.com/f/nordic-q-a/19074/can-i-change-nrf5-bluetooth-advertising-interval-dynamically/73766#73766
  • Hi Yaniv,
    Please take a look in the "Advertising Module documentation".
    Usually you have advertising go from  Fast -> Slow -> Idle.
    Do you only want to change from Fast -> Slow -> Fast -> Slow ? (aka. never enter sleep_mode?)
    If so you could just add that when Slow_adv_timeout runs out you go back to fast_adv in the IDLE case:
     switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
    						NRF_LOG_INFO("FAST ADVERTISING");
    				case BLE_ADV_EVT_SLOW:
    					err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
    					NRF_LOG_INFO("SLOW ADVERTISING");
            case BLE_ADV_EVT_IDLE:
    					  //NRF_LOG_INFO("IDLE");
                //sleep_mode_enter();
