Getting started with SPI
Hello. I have a nRF52832 DK and I'm trying to modify the SPI example code found here:
/nRF5_SDK_15.0.0/nRF5_SDK_15.0.0_a53641a/examples/peripheral/spi
I'm using the nRF52832 DK as the master and a digital potentiometer (MCP4131) as the slave, and Netbeans 8.2 as my IDE.
I want to be able to read and write to registers as well as perform commands as described in section 7 of the MCP4131 datasheet.
I've been able to send the "Nordic" string on the MOSI bus that I read on an oscilloscope. However, I'm struggling to write hexadecimal values to the following function:
<APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));>
I've tried modifying the value of TEST_STRING from "Nordic" to various hexadecimal formats such as 0x80, %80x, 0X80, "0x80", etc. but I get various errors when I try to do this.
Shouldn't I be able to store a hex value in a static uint8_t value? I feel like I'm missing something obvious here.
Any help would be greatly appreciated! Here is the complete example code for reference:
* Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
NRF_LOG_INFO("SPI example started.");
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf,m_length, m_rx_buf, m_length));
//NRF_DRV_SPI_XFER_TX(m_tx_buf, m_length);
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
nrf_delay_us(1000000);
  • Hey Payton,
    What error do you get when you replace "Nordic" with "0x80" ?
    Also I suggest you try Segger Embedded Studio for any embedded development with our devices as we do not support Netbeans in our SDK.
    Cheers,
    Håkon.
  • Thanks for the response! No error is given because a variable in quotes is seen as a string and saved as ASCII in the register, similar to how "Nordic" is saved (apologies, I should have said "various issues" not "various errors"). Replacing "Nordic" with "0x80" in the code sends the ASCII 'version' of 0x80 on MOSI. ie, using a conversion tool, one can see that 0x80 is saved as 00110000 01111000 00111000 00110000 0001010. This binary value is exactly what is transmitted on MOSI, as I can see from using an oscilloscope. My issue is that some 8-bit binary values cannot be accessed by ASCII characters (eg, see binary values 10000000-10011111 on an extended ASCII table). So basically I need a way to save these and other values to static uint8_t m_tx_buf[] without using quotes and strings.
  • Hey Payton,
    I was convinced that we were talking about UART for some reason, but now I realize it's SPI.
    We're gonna start by reading the status register:
    uint16_t MOSI; //TX buffer
    uint16_t MISO; //RX buffer
    MOSI = 0b0101111111111111; //4 bits address (0x5) + 2 control bits (0x3=read) +    \
    //10 bits data.
    //The data bits on MOSI are called the Over Read Character and is used to let the  \
    //slave continue to send even though the master has sent want it needs for the     \
    //current transfer. Most SPI slaves needs an ORC of 0xFF/0b11111111 to function    \
    //properly.
    //After the transfer is complete you need to extract the data bits out of MISO:
    uint16_t DATA = MISO & 0b0000001111111111; // The mask of actual data bits.
    To make things more readable you can do the following:
    # define DATA_MSK 0b0000001111111111
    // Now you can extract the bits in a more human-readable form
    uint16_t DATA = MISO & DATA_MSK;
    More advanced:
    #define WIPER0_ADDR 0x00
    #define TCON_ADDR   0x04
    #define STATUS_ADDR 0x05
    #define WRITE_CMD   0x00
    #define INCR_CMD    0x01
    #define DECR_CMD    0x02
    #define READ_CMD    0x03
    #define ADDR_POS    12
    #define CMD_POS     10
    uint16_t encode_tx_buffer(uint8_t addr, uint8_t cmd)
        return ((addr << ADDR_POS)|(cmd << CMD_POS) | DATA_MSK);
    // To read the status register now:
    uint16_t MOSI = encode_tx_buffer(STATUS_ADDR, READ_CMD);
    // Should be equal to 0b0101111111111111.
    I wrote the code in this text editor so there might be some unwanted "features" present, just a heads-up.
    Cheers,
    Håkon.
