DFU SDK13. Problems with update. Starnge behavior.
I implemented DFU secure ble. And implemented encryption. But now I remarked strange behavior. If make same DFU packet (.zip) and flah nRF52 than update firmware for same packet DFU- all OK. If flash nrf52 one firmware and than make small changes in the project and make DFU and update it- all OK. But if I make in project to many changes (compile same project from one optimization (-0) to 3nd optimization, for example) and than flash via DFU- project doesn't works. Project starts with new firmware and always has reboot.
As recommended I made next changes:
in a file dfu_req_handles.c
insert to line 589
case DFU_FW_TYPE_APPLICATION:
                p_bank->image_crc = crc32_compute((uint8_t *)MAIN_APPLICATION_START_ADDR, m_firmware_size_req, NULL);
line 637 just comment:
        // Calculate CRC32 for image
//        p_bank->image_crc = s_dfu_settings.progress.firmware_image_crc; // az comment
        p_bank->image_size = m_firmware_size_req;
and between 1004 -1005 and 1044-1045 I insert block for decrypt image:
for (int i = 0; i < m_data_buf_pos; i+=16)
                    AES128_ECB_decrypt (&m_data_buf[m_current_data_buffer][i], key, &m_data_buf[m_current_data_buffer][i]);
at this changes I received wrong CRC in a file components/libraries/bootloader/dfu/nrf_dfu_utils.c
I just made changes in line 165;
s_dfu_settings.bank_1.image_crc = crc;
therefore I just ignore if CRC was wrong, but didn't decide real problem.
How to correct make changes for normal work DFU with encryped image?
    line 589 seems to calculate the checksum of the application image in bank 0, so will not be valid if you do a dual-bank update as the new image will be stored in bank 1. Maybe that's what you are seeing; bootloader performs single bank update when you compile the app without compiler optimization due to limited flash space, and dual bank when you compile with optimization? In any case, I think you need to calculate the checksum of the image in bank 1 when s_dfu_settings.bank_current == NRF_DFU_CURRENT_BANK_1.
  • Thanks. Possible You right. But I just check pure dfu_bootloader with no changes and works fine.
    But I need to encrypt my firmware.
    Can You advise me in which places should change code for correct unpuck encrypted firmware. And correct I call 2 times AES128_ECB_decrypt ()?
  • Yes the standard bootloader works, but when and where to calculate the CRC changes when you introduce encryption. As I said in my previous reply, it looks like you are calculating the checksum of the old FW image.
  • Hi! Can You advise me in wich plase should insert CRC check?
    decrypt in 2 plases did I correct?
    Or if CRC not correct when check it, but in file nrf_dfu_utils.c in the DFU project, I after line 164 add
    Therefore I cheating CRC check and DFU on smartfone write that firmware updated sucessfull.
  • So. No problems with encreption like I discribe before. All works correct. And AES encription to.
    But my problem has another reason.
    I use block code for non updatable data. I located it
    volatile type_struct my_struct1 __attribute__((section(".ARM.__at_0x72400"))) =
    volatile type_struct my_struct2 __attribute__((section(".ARM.__at_0x72500"))) =
    At this case this struct not updated from bootloader. But in the .hex after compile I have some code after 0x72500. This code more than size of struct.
    And, as I understand, after apdate for another firmware, this code also changed. But when update done, this part of code doesn't updated and programm crushed. and than reboot.
    Therefore - no problems with encript and CRC.
    How to say to Keil that don't need to add any code to the end of structure?
