BLE_APP_UART example not working properly.
Hello everyone, I am very new to nRF52832 Development Kit and was testing some examples to get familiar with this kit, however i encountered an issue while testing the ble_app_uart example.
I followed the instructions provided by nordic infocenter line by line.
My configuration settings are
Baud rate : 38400
Com Port : COM6 (verified through device manager)
flow control : disabled
parity none, 8 data bits, 1 stop bit
and I am using termite.
The issue that i encountered and could not resolve although i tried a lot is that my nRF toolbox or nRF connect app is not able to receive anything which i send from the termite towards the phone. However if i send any character from the phone, it's received and displayed at termite windows perfectly. So what basically is the problem? Why i can receive data from toolbox or connect app but can't transmit data towards them. Please help me out. Thanks
    Default baudrate for ble_app_uart  has been 115200 since SDK version 11, are you using an older version? Note that SDK 11 was the first SDK version to support the nRF52 series.
    Link to latest SDK: http://www.nordicsemi.com/eng/nordic/Products/nRF52-DK/nRF5-SDK-zip/59014
  • Hello, Thank you so much for your response.
    Sir, I am using SDK version 15 and the example is ble_app_uart. I have also set the baud rate within the example code to 38400 but still nRF connect only transmits data to Termite but does not receive it.
  • Hello, did you enable notifications on the TX characteristic? nRF connect must enable notifications in order to receive notifications from the peripheral. In addition, the app will buffer UART data until it reaches "m_ble_nus_max_data_len" number of bytes or until it receives a newline ('\n') , then send the notification packet. In other words, notification will not be sent if you only write "Hello" without terminating it with a newline.
     You could try to replace '\n' with '\r' In case the serial client doesn't append a newline to the text string. With this change you should see that the notification gets sent as soon as you press enter
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\r') || (index >= (m_ble_nus_max_data_len)))
  • I had done everything as you have mentioned here sir. Dont know what the actual reason of the problem was, but now transmission and reception and working perfectly great. Dont know what happened or how it happened but suddenly the example is running perfectly. Thank you so much for your time sir.
