I've been going off of the Buttonless DFU example to integrate DFU functionality into an existing project on a custom board. While I seem to have added the necessary includes and code to compile without errors, my board bootloops when it executes the code. After stepping through the code in debug mode in Eclipse, it appears that the hard fault occurs at the sd_softdevice_enable_request(), in particular when it makes the SVCALL to sd_softdevice_enable(). I'm unable to see what the actual signal returns to induce the failure.
I modified my linker script to match the memory layout of the buttonless DFU example. I also added relevant DFU configuration code to sdk_config.h, and then integrated the appropriate methods for initializing DFU from the example (app_shutdown_handler, ble_dfu_evt_handler, pm_evt_handler, peer_manager_init, delete_bonds, advertising_start) as well as necessary additions to services_init() and ble_init().
The curious thing is that all of these additions occur after the call to sd_softdevice_enable_request(). This makes me suspect that the problem has to do with changes to sdk_config.h, or changes to my Makefile. The biggest changes to sdk_config.h appear to be changing PEER_MANAGER_ENABLED from 0 to 1, PM_CENTRAL_ENABLED from 1 to 0, NRF_SDH_BLE_GAP_EVENT_LENGTH 7 to 3, NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247 to 23, NRF_SDH_BLE_SERVICE_CHANGED 0 to 1.
For the Makefile, the memory layout was altered from
to
with an additional section:
I can include any additional files or sections of code. I realize this isn't very much to go off of, but I'm scratching my head over this, seeing as the bootloop is occurring at a point in the code in which things have not been altered prior to attempting to integrate the DFU code.
EDIT: there is one other detail I forgot to mention that may be a major factor here: In order to resolve an Implicit Declaration error within my build, I included "nrf_sdm.h" within the file initializing my BLE stack. This wasn't included in the example code, perhaps its resulting in improper initialization of the soft device.
