light_switch example SDK v2.0.1 -- Problem with server
Dear all,
I am testing the light_switch demo (SDK for Mesh v2.0.1 and softdevice 6.0.0) below the following configuration:
-- One client: nrf52-PCA10040 DK (light_switch_client_nrf52832_xxAA_s132)
-- One server: nrf52-PCA10040 DK (light_switch_server_nrf52832_xxAA_s132)
-- One provisioner: nrf52-PCA10056 DK (light_switch_provisioner_nrf52840_xxAA_s140)
In light_switch_example_common.h:
#define SERVER_NODE_COUNT (1)
#define CLIENT_NODE_COUNT (1)
After programming all boards and debugging the provisioner I get:
   0>, main.c,  550, ----- BLE Mesh Light Switch Provisioner Demo -----
<t:          0>, mesh_softdevice_init.c,  112, Initializing SoftDevice...
<t:          0>, mesh_softdevice_init.c,   77, Enabling BLE...
<t:          2>, mesh_softdevice_init.c,   88, Ram base: 0x200032C8
<t:        547>, main.c,  488, Initializing and adding models
<t:        581>, main.c,  441, Restored: App data
<t:        583>, main.c,  540, Restored: Handles
<t:        586>, provisioner_helper.c,  301, m_netkey_handle:0 m_appkey_handle:0 m_self_devkey_handle:1
<t:        592>, main.c,  578, <start>
<t:      26844>, main.c,  565, Starting application ...
<t:      26846>, main.c,  567, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100
<t:      26850>, main.c,  568, Dev key : DD9DFDF59BC9645D89C114C86B2A6F80
<t:      26853>, main.c,  569, Net key : 19C47451084A42576555EE0EABDE9E14
<t:      26856>, main.c,  570, App key : 15C3C014F3B5593AD1EC2A6FE572F309
<t:      26859>, main.c,  571, Press Button 1 to start provisioning and configuration process.
<t:     191475>, main.c,  448, Button 1 pressed
<t:     191477>, main.c,  361, Waiting for Client node to be provisioned ...
<t:     196239>, provisioner_helper.c,  282, Scanning For Unprovisioned Devices
<t:     201799>, provisioner_helper.c,  144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
<t:     201802>, provisioner_helper.c,   95, UUID filter matched
<t:     202407>, provisioner_helper.c,  259, Provisioning link established
<t:     216232>, provisioner_helper.c,  254, Static authentication data provided
<t:     228301>, provisioner_helper.c,  192, Provisioning completed received
<t:     228304>, provisioner_helper.c,  197, Adding device address, and device keys
<t:     228309>, provisioner_helper.c,  214, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
<t:     232418>, provisioner_helper.c,  155, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:     232422>, main.c,  282, Provisioning successful
<t:     232424>, provisioner_helper.c,  181, Provisioning complete. Node addr: 0x0100 elements: 5
<t:     232428>, node_setup.c,  672, Configuring Node: 0x0100
<t:     232431>, node_setup.c,  586, Config client setup: devkey_handle:2 addr_handle:0
<t:     232435>, node_setup.c,  361, Getting composition data
<t:     232475>, main.c,  117, Flash write complete
<t:     286192>, main.c,  332, Config client event
<t:     286195>, node_setup.c,  371, Adding appkey
<t:     290313>, main.c,  332, Config client event
<t:     290315>, node_setup.c,  234, Unexpected opcode: exp 0x8003  rx 0x0002
<t:     291984>, main.c,  332, Config client event
<t:     291986>, node_setup.c,  272, opcode status field: 0
<t:     291989>, node_setup.c,  382, App key bind: Health server
<t:     292886>, main.c,  332, Config client event
<t:     292889>, node_setup.c,  272, opcode status field: 0
<t:     292891>, node_setup.c,  450, Setting publication address for the health server to 0x0001
<t:     295957>, main.c,  332, Config client event
<t:     295959>, node_setup.c,  272, opcode status field: 0
<t:     295962>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0101
<t:     297624>, main.c,  332, Config client event
<t:     297627>, node_setup.c,  272, opcode status field: 0
<t:     297629>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0102
<t:     298344>, main.c,  332, Config client event
<t:     298347>, node_setup.c,  272, opcode status field: 0
<t:     298349>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0103
<t:     300170>, main.c,  332, Config client event
<t:     300172>, node_setup.c,  272, opcode status field: 0
<t:     300174>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0104
<t:     301127>, main.c,  332, Config client event
<t:     301129>, node_setup.c,  272, opcode status field: 0
<t:     301132>, node_setup.c,  301, Set: on/off client: 0x0101  pub addr: 0x0105
<t:     304897>, main.c,  332, Config client event
<t:     304899>, node_setup.c,  272, opcode status field: 0
<t:     304902>, node_setup.c,  301, Set: on/off client: 0x0102  pub addr: 0x0106
<t:     308733>, main.c,  332, Config client event
<t:     308736>, node_setup.c,  272, opcode status field: 0
<t:     308738>, node_setup.c,  301, Set: on/off client: 0x0103  pub addr: 0xC003
<t:     313549>, main.c,  332, Config client event
<t:     313551>, node_setup.c,  272, opcode status field: 0
<t:     313553>, node_setup.c,  301, Set: on/off client: 0x0104  pub addr: 0xC002
<t:     318005>, main.c,  332, Config client event
<t:     318007>, node_setup.c,  272, opcode status field: 0
<t:     318010>, main.c,  248, Configuration of device 0 successful
<t:     318013>, main.c,  267, All servers provisioned
<t:     370499>, main.c,  117, Flash write complete
However, pressing Button 1 on the client board doesn't have any effect on server. Am I making a mistake?
    The example should work regardless of the SERVER_NODE_COUNT setting (as long as it is high enough to cover all your servers.) However I have experienced that it might be necessary to reset the server for it to work properly.
    Please also note that you may have to erase the full flash contents (nrfjprog -e) before programming the boards, since the configurations are stored in a separate area in flash that is not rewritten when you program the example. When things are not working properly it may be because of old configurations in the devices.
    Terje
  • Hi.
    I have the same problem with the server. I don't know Bluetooth very well, but it's weird that the server doesn't get the address.
    <t: 0>, main.c, 247, ----- BLE Mesh Light Switch Client Demo -----
    <t: 562>, main.c, 220, Initializing and adding models
    <t: 5422>, main.c, 275, Device UUID : 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 937009>, main.c, 98, Successfully provisioned
    <t: 937011>, main.c, 102, Node Address: 0x0100
    <t: 0>, main.c, 177, ----- BLE Mesh Light Switch Server Demo -----
    <t: 672>, main.c, 150, Initializing and adding models
    <t: 5556>, main.c, 205, Device UUID : 0059FFFF00000000218319663B85E9BB
    <t: 0>, main.c, 550, ----- BLE Mesh Light Switch Provisioner Demo -----
    <t: 629>, main.c, 488, Initializing and adding models
    <t: 640>, main.c, 531, Setup defaults: Adding keys, addresses, and bindings
    <t: 804>, provisioner_helper.c, 329, netkey_handle: 0
    <t: 816>, main.c, 578, <start>
    <t: 27281>, main.c, 117, Flash write complete
    <t: 27284>, main.c, 565, Starting application ...
    <t: 27286>, main.c, 567, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100
    <t: 27290>, main.c, 568, Dev key : C30E63BCBBA95DE6E75F4C7E5A7D5C97
    <t: 27293>, main.c, 569, Net key : 68D6724AD28AB95236DF4007ECFF55F0
    <t: 27296>, main.c, 570, App key : 38D6B422819AC84BF74B847AE148E5C2
    <t: 27299>, main.c, 571, Press Button 1 to start provisioning and configuration process.
    <t: 231574>, main.c, 448, Button 1 pressed
    <t: 231576>, main.c, 361, Waiting for Client node to be provisioned ...
    <t: 236337>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
    <t: 253384>, provisioner_helper.c, 144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
    <t: 253387>, provisioner_helper.c, 95, UUID filter matched
    <t: 254355>, provisioner_helper.c, 259, Provisioning link established
    <t: 267133>, provisioner_helper.c, 254, Static authentication data provided
    <t: 279603>, provisioner_helper.c, 192, Provisioning completed received
    <t: 279607>, provisioner_helper.c, 197, Adding device address, and device keys
    <t: 279611>, provisioner_helper.c, 214, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    <t: 283836>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2
    <t: 283841>, main.c, 282, Provisioning successful
    <t: 283844>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x0100 elements: 5
    <t: 283847>, node_setup.c, 672, Configuring Node: 0x0100
    <t: 283851>, node_setup.c, 586, Config client setup: devkey_handle:2 addr_handle:0
    <t: 283854>, node_setup.c, 361, Getting composition data
    <t: 283895>, main.c, 117, Flash write complete
    <t: 337260>, main.c, 332, Config client event
    <t: 337263>, node_setup.c, 371, Adding appkey
    <t: 345407>, main.c, 332, Config client event
    <t: 345409>, node_setup.c, 234, Unexpected opcode: exp 0x8003 rx 0x0002
    <t: 349599>, main.c, 332, Config client event
    <t: 349601>, node_setup.c, 234, Unexpected opcode: exp 0x8003 rx 0x0002
    <t: 351336>, main.c, 332, Config client event
    <t: 351338>, node_setup.c, 272, opcode status field: 0
    <t: 351341>, node_setup.c, 382, App key bind: Health server
    <t: 352047>, main.c, 332, Config client event
    <t: 352049>, node_setup.c, 272, opcode status field: 0
    <t: 352052>, node_setup.c, 450, Setting publication address for the health server to 0x0001
    <t: 355376>, main.c, 332, Config client event
    <t: 355379>, node_setup.c, 272, opcode status field: 0
    <t: 355381>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0101
    <t: 360505>, main.c, 332, Config client event
    <t: 360507>, node_setup.c, 272, opcode status field: 0
    <t: 360510>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0102
    <t: 361353>, main.c, 332, Config client event
    <t: 361355>, node_setup.c, 272, opcode status field: 0
    <t: 361358>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0103
    <t: 362311>, main.c, 332, Config client event
    <t: 362313>, node_setup.c, 272, opcode status field: 0
    <t: 362315>, node_setup.c, 416, App key bind: Simple On/Off client on element 0x0104
    <t: 363063>, main.c, 332, Config client event
    <t: 363066>, node_setup.c, 272, opcode status field: 0
    <t: 363068>, node_setup.c, 301, Set: on/off client: 0x0101 pub addr: 0x0105
    <t: 366317>, main.c, 332, Config client event
    <t: 366319>, node_setup.c, 272, opcode status field: 0
    <t: 366322>, node_setup.c, 301, Set: on/off client: 0x0102 pub addr: 0x0106
    <t: 370645>, main.c, 332, Config client event
    <t: 370647>, node_setup.c, 272, opcode status field: 0
    <t: 370650>, node_setup.c, 301, Set: on/off client: 0x0103 pub addr: 0xC003
    <t: 382175>, main.c, 332, Config client event
    <t: 382177>, node_setup.c, 272, opcode status field: 0
    <t: 382180>, node_setup.c, 301, Set: on/off client: 0x0104 pub addr: 0xC002
    <t: 386570>, main.c, 332, Config client event
    <t: 386572>, node_setup.c, 272, opcode status field: 0
    <t: 386574>, main.c, 248, Configuration of device 0 successful
    <t: 386578>, main.c, 267, All servers provisioned
    <t: 439070>, main.c, 117, Flash write complete
    <t: 441871>, main.c, 332, Config client event
  • Hi tesc,
    I tried to stablish the same configuration following the tutorial "Interactive mesh provisioning and configuration" (Software Development Kit > nRF5 SDK for Mesh > nRF5 SDK for Mesh v2.0.1 > Scripts > Interactive PyACI).
    It seems that the client is not properly configured, since pressing Button 1 on client doesn't have any effect on server. However, if the Publishing and Subscribing feature is configured, when I change the state of the server the client also changes.
    A quick update on this one. There is an error in the provisioner example so that both clients and servers counts towards the SERVER_NODE_COUNT.
    In main.c of the provisioner example, find the comparisons "m_nw_state.provisioned_devices < SERVER_NODE_COUNT" and "m_nw_state.configured_devices < SERVER_NODE_COUNT". Replace "SERVER_NODE_COUNT" with "(SERVER_NODE_COUNT + CLIENT_NODE_COUNT)".
    Terje
