I'm in the process of migrating from SDK 14.2.0 S140 5.0.0-2.alpha to SDK 15.0.0 with S140 6.0.0 on an nRF5280 based custom board.
It should be possible to do a secure DFU upgrade of BL+SD+APP by creating a zip package containing all these items. The BL+SD will be upgraded first, followed by the appliation.
The following command has been used to generate the BL+SD+APP zip package where 0x96=S140 5.0.0 and 0xa9=S140 6.0.0 with appropriate hex file inputs.
nrfutil pkg generate \
--hw-version 52 \
--sd-req 0x96,0xa9 \
--bootloader-version "$version_as_int" \
--bootloader "$bootloader_path_dest" \
--softdevice s140_nrf52_6.0.0_softdevice.hex \
--sd-id 0xa9 \
--application "$app_firmware_path_dest" \
--application-version "$version_as_int" \
--key-file src/bootloader/private.key \
"$app_sd_bl_firmware_dfu_dest"
After succesfully bonding in the app running from SDK 14.2.0 and initiating DFU using PC nRF Connect v2.3.0, the DFU download of BL+SD occurs and then hangs at 99% waiting for
the target device to respond.
If I turn on RTT logging for the SDK 14.2.0 bootloader, it's clear that the bootloader is in a reboot loop and outputs the following messages:
<info> app: Inside main
<debug> app: In nrf_bootloader_init
<debug> app: in custom nrf_dfu_init_user
<debug> app: In real nrf_dfu_init
<debug> nrf_dfu_settings: Running nrf_dfu_settings_init(sd_irq_initialized=false).
<debug> nrf_dfu_flash: Calling nrf_dfu_flash_init(sd_irq_initialized=false)...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<debug> app: Initializing the clock.
<debug> app: Enter nrf_dfu_continue
<debug> app: Valid SD + BL
<debug> app: Enter nrf_dfu_sd_bl_continue
<debug> app: Enter nrf_bootloader_dfu_sd_continue
<debug> app: SD already copied
<debug> app: Verifying BL: Addr: 0x000E0000, Src: 0x000A43C8, Len: 0x0000AB74
<debug> app: Bootloader not verified, copying: Src: 0x000A43C8, Len: 0x0000AB74
**** Device resets and loops with the same messages ****
I have used nrfjprog to verify that the flash contents at 0xa43c8 do contain the new BL downloaded as part of the DFU zip package.
The nrf_dfu_mbr_copy_bl SVC call issued during the upgrade seems to result in a reset. I've added logging after the call, but the SVC call into the MBR never returns.
I'm using the following locations for binaries:
Binaries programmed from sdk 14.2.0
Bootloader 0xe0000, len 0x1e000
Bootloader settings page 0xff000, len 0x1000
MBR params page 0xfe000, len 0x1000
App 0x22000, len 0xbb000
app_data 0xdd000, len 0x3000
Updated binaries based on sdk 15.0.0 for BL+SD+APP DFU
App 0x26000, len 0xb7000 (Note: Both flash and RAM allocations for app have moved from sdk 14.2.0)
I have see this post but I don't believe this is relevant for SDK 14.2.0 and later.
How do I go about debugging this issue further?
