I would like to know how can I configure the parameter NRF_SDH_BLE_GAP_EVENT_LENGTH for a determined NRF_SDH_BLE_GATT_MAX_MTU_SIZE when enabling data extension.
I have defined my NRF_SDH_BLE_GATT_MAX_MTU_SIZE as 158 bytes set my softdevice to use 7 characteristics and to use the connection event lenght extension as shown below
void gatt_mtu_set(uint16_t att_mtu) { ret_code_t err_code; err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, att_mtu); APP_ERROR_CHECK(err_code); err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, att_mtu); APP_ERROR_CHECK(err_code); } void conn_evt_len_ext_set(bool status) { ret_code_t err_code; ble_opt_t opt; memset(&opt, 0x00, sizeof(opt)); opt.common_opt.conn_evt_ext.enable = status ? 1 : 0; err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt); APP_ERROR_CHECK(err_code); } void data_len_set(uint8_t value) { ret_code_t err_code; err_code = nrf_ble_gatt_data_length_set(&m_gatt, BLE_CONN_HANDLE_INVALID, value); APP_ERROR_CHECK(err_code); m_test_params.data_len = value; } static void ble_stack_init(void) { uint32_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // BLE Configuration ble_cfg_t ble_cfg; // Max Packets Per Connection Event memset(&ble_cfg, 0, sizeof ble_cfg); ble_cfg.conn_cfg.conn_cfg_tag = APP_BLE_CONN_CFG_TAG; ble_cfg.conn_cfg.params.gatts_conn_cfg.hvn_tx_queue_size = 7; err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTS, &ble_cfg, ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); }
However, I do not know what are the righet values for NRF_SDH_BLE_GAP_EVENT_LENGTH and how shoud I suppose to calculte it. Could you provide me some hints about it?
Thanks in advance,
Kind regards
