sd_ble_enable causing hang if application is jumped to from bootloader
I am using sd 7.0.0, I have a simple bootloader implementation that follows the bootloader sample code pretty closely. When I jump to my application from the bootloader and call sd_ble_enable, it hangs inside the SVC_handler. If I load my application without the bootloader, it runs fine. I do not enable sd inside my bootloader anywhere. I also know that main() inside the application is being reached. Here is my code that handles setting up the vector table address and jumping to the application.
void StartApplication(void)
    interrupts_disable();
    sd_mbr_command_t com = {SD_MBR_COMMAND_VECTOR_TABLE_BASE_SET, CODE_START};
    sd_mbr_command(&com);
    JumpToApplication(CODE_START);
void JumpToApplication(uint32_t start_addr)
    __asm volatile("LDR   R2, [R0]\t\n"
          "MSR   MSP, R2\t\n"
          "LDR   R3, [R0, #0x00000004]\t\n"
          "BX    R3\t\n"
          ".ALIGN\t\n");
I have no idea what I am doing wrong. Any help would be greatly appreciated.
