Failed to receive scan_response
Hello everyone,
I've been trying to get scan_response data from a specific advertiser. Advertiser being nrf52810 running the s112 SoftDevices and Scanner being nrf52832 running the s132 SoftDevices. When I scan for devices Scanner detects the advertiser, but due to some problem, it's not able to get the scan response data. I scanned for devices using nRF Connect Android app. There I received scan response data perfectly from the same advertiser.
I'm setting ble_gap_scan_params_t as given below:
    .active   = 1,
    .interval = (BLE_GAP_SCAN_INTERVAL_MAX),
    .window   = (BLE_GAP_SCAN_WINDOW_MAX),
    .extended = 0,
    .report_incomplete_evts = 0,
    .channel_mask = {0,0,0,0,0},
    .timeout           = BLE_GAP_SCAN_TIMEOUT_UNLIMITED,
    .scan_phys         = BLE_GAP_PHY_AUTO,
    .filter_policy     = BLE_GAP_SCAN_FP_ACCEPT_ALL,
I'm also scanning in continues mode.
Also, I already know the MAC address of the advertiser device. So I'm filtering out all the other devices.
The summary for the event handler for BLE_GAP_EVT_ADV_REPORT is as follow:
//req_mac_addr = MAC address of target advertiser.
//current_mac_addr = MAC address of most recently scanned advertiser.
    if(mem_cmp(req_mac_addr, current_mac_addr, 6) == 0)
            print_data_from_evt(Data_in_Receiver_buffer);
            print_data_from_evt(Scan_Response_Value_from ble_gap_adv_report_type_t);
Here Scan_Response_Value is always zero and hence I can't get scan response data.
please suggest me something if you can.
    Does the device keep scanning after getting an address match on the main advertisement packet?  Looks like you have configured everything correctly, but not sure what happens after you get a match. Could you try to add this code to your BLE_GAP_EVT_ADV_REPORT event and comment out the rest just to check if it ever receives a scan response from this device:
        uint8_t req_mac_addr[] = {0x85, 0x8d, 0x5e, 0x32, 0xBC, 0xAC}; // Insert address here
        if(!memcmp(req_mac_addr, p_adv_report->peer_addr.addr, sizeof(req_mac_addr)))
            if (p_adv_report->type.scan_response)
                __BKPT(0); // Break here if we received scan response from known device
