How can i add more nodes server in light switch example in Mesh SDK 1.0.0?
How can i add more nodes server in light switch example in Mesh SDK 1.0.0?, i change #define SERVER_COUNT to 52 and work fine, but when i change it to more than 52 don´t let me compile.
  • Hi
    Can you provide some more information on the failure?
    Most likely you are running out of memory, as each additional server needs a certain amount of RAM.
    I am also a bit curious why you need so many servers?
    Most use cases require far less than that.
    I would also recommend switching to version 2.0.1 of the mesh SDK if you can, as it includes several improvements over v1.
    Best regards
    Torbjørn
