Sending commands to peripheral in nRF Toolbox app
Hi all,
I'm currently learning on how to build bluetooth connections with a device from an app. For that I downloaded the iOS version of the nerf Toolbox app, as my chip is also from nRF. There I want to send some String to the peripheral with the line:
bluetoothManager2!.send(text: "h\r\n" + "r\r\n")
to get the sensor values into my app. Note that I have to initiate the Firmware by h and r to send two set of values. I build that into the following code:
//  NORScannerViewController.swift
import UIKit
import CoreBluetooth
fileprivate func < <T : Comparable>(lhs: T?, rhs: T?) -> Bool {
  switch (lhs, rhs) {
  case let (l?, r?):
    return l < r
  case (nil, _?):
    return true
    return false
fileprivate func > <T : Comparable>(lhs: T?, rhs: T?) -> Bool {
  switch (lhs, rhs) {
  case let (l?, r?):
    return l > r
    return rhs < lhs
class NORScannerViewController: UIViewController, CBCentralManagerDelegate, UITableViewDelegate, UITableViewDataSource, NORBluetoothManagerDelegate {
    let dfuServiceUUIDString  = "00001530-1212-EFDE-1523-785FEABCD123"
    let ANCSServiceUUIDString = "7905F431-B5CE-4E99-A40F-4B1E122D00D0"
    //MARK: - ViewController Properties
    var bluetoothManager : CBCentralManager?
    var bluetoothManager2 : NORBluetoothManager?
    var delegate         : NORScannerDelegate?
    var delegate2       : NORBluetoothManagerDelegate?
    var filterUUID       : CBUUID?
    var peripherals      : [NORScannedPeripheral]
    var timer            : Timer?
    @IBOutlet weak var devicesTable: UITableView!
    @IBOutlet weak var emptyView: UIView!
    @IBAction func cancelButtonTapped(_ sender: AnyObject) {
        self.dismiss(animated: true, completion: nil)
    @objc func timerFire() {
        if peripherals.count > 0 {
            emptyView.isHidden = true
            devicesTable.reloadData()
    required init?(coder aDecoder: NSCoder) {
        peripherals = []
        super.init(coder: aDecoder)
    func getRSSIImage(RSSI anRSSIValue: Int32) -> UIImage {
        var image: UIImage
        if (anRSSIValue < -90) {
            image = UIImage(named: "Signal_0")!
        } else if (anRSSIValue < -70) {
            image = UIImage(named: "Signal_1")!
        } else if (anRSSIValue < -50) {
            image = UIImage(named: "Signal_2")!
        } else {
            image = UIImage(named: "Signal_3")!
        return image
    func didConnectPeripheral(deviceName aName: String?) {
    func didDisconnectPeripheral() {
    func peripheralReady() {
    func peripheralNotSupported() {
    func getConnectedPeripherals() -> [CBPeripheral] {
        guard let bluetoothManager = bluetoothManager else {
            return []
        var retreivedPeripherals : [CBPeripheral]
        if filterUUID == nil {
            let dfuServiceUUID       = CBUUID(string: dfuServiceUUIDString)
            let ancsServiceUUID      = CBUUID(string: ANCSServiceUUIDString)
            retreivedPeripherals     = bluetoothManager.retrieveConnectedPeripherals(withServices: [dfuServiceUUID, ancsServiceUUID])
        } else {
            retreivedPeripherals     = bluetoothManager.retrieveConnectedPeripherals(withServices: [filterUUID!])
        return retreivedPeripherals
     * Starts scanning for peripherals with rscServiceUUID.
     * - parameter enable: If YES, this method will enable scanning for bridge devices, if NO it will stop scanning
     * - returns: true if success, false if Bluetooth Manager is not in CBCentralManagerStatePoweredOn state.
    func scanForPeripherals(_ enable:Bool) -> Bool {
        guard bluetoothManager?.state == .poweredOn else {
            return false
        DispatchQueue.main.async {
            if enable == true {
                let options: NSDictionary = NSDictionary(objects: [NSNumber(value: true as Bool)], forKeys: [CBCentralManagerScanOptionAllowDuplicatesKey as NSCopying])
                if self.filterUUID != nil {
                    self.bluetoothManager?.scanForPeripherals(withServices: [self.filterUUID!], options: options as? [String : AnyObject])
                } else {
                    self.bluetoothManager?.scanForPeripherals(withServices: nil, options: options as? [String : AnyObject])
                self.timer = Timer.scheduledTimer(timeInterval: 1.0, target: self, selector: #selector(self.timerFire), userInfo: nil, repeats: true)
            } else {
                self.timer?.invalidate()
                self.timer = nil
                self.bluetoothManager?.stopScan()
        return true
    //MARK: - ViewController Methods
    override func viewDidLoad() {
        super.viewDidLoad()
        devicesTable.delegate = self
        devicesTable.dataSource = self
        let activityIndicatorView              = UIActivityIndicatorView(activityIndicatorStyle: UIActivityIndicatorViewStyle.gray)
        activityIndicatorView.hidesWhenStopped = true
        self.navigationItem.rightBarButtonItem = UIBarButtonItem(customView: activityIndicatorView)
        activityIndicatorView.startAnimating()
        let centralQueue = DispatchQueue(label: "no.nordicsemi.nRFToolBox", attributes: [])
        bluetoothManager = CBCentralManager(delegate: self, queue: centralQueue)
    override func viewWillAppear(_ animated: Bool) {
        super.viewWillAppear(animated)
        UIApplication.shared.setStatusBarStyle(UIStatusBarStyle.default, animated: true)
    override func viewWillDisappear(_ animated: Bool) {
        let success = self.scanForPeripherals(false)
        if !success {
            print("Bluetooth is powered off!")
        UIApplication.shared.setStatusBarStyle(UIStatusBarStyle.lightContent, animated: true)
        super.viewWillDisappear(animated)
    //MARK: - UITableViewDataSource
    func tableView(_ tableView: UITableView, numberOfRowsInSection section: Int) -> Int {
        return peripherals.count
    func tableView(_ tableView: UITableView, cellForRowAt indexPath: IndexPath) -> UITableViewCell {
        let aCell = tableView.dequeueReusableCell(withIdentifier: "Cell", for: indexPath)
        //Update cell content
        let scannedPeripheral = peripherals[indexPath.row]
        aCell.textLabel?.text = scannedPeripheral.name()
        if scannedPeripheral.isConnected == true {
            aCell.imageView!.image = UIImage(named: "Connected")
        } else {
            let RSSIImage = self.getRSSIImage(RSSI: scannedPeripheral.RSSI)
            aCell.imageView!.image = RSSIImage
        return aCell
    //MARK: - UITableViewDelegate
    func tableView(_ tableView: UITableView, didSelectRowAt indexPath: IndexPath) {
        bluetoothManager!.stopScan()
        // Call delegate method
        let peripheral = peripherals[indexPath.row].peripheral
        self.delegate?.centralManagerDidSelectPeripheral(withManager: bluetoothManager!, andPeripheral: peripheral)
    func centralManagerDidSelectPeripheral(withManager aManager: CBCentralManager, andPeripheral aPeripheral: CBPeripheral) {
        // We may not use more than one Central Manager instance. Let's just take the one returned from Scanner View Controller
        bluetoothManager2 = NORBluetoothManager(withManager: aManager)
        bluetoothManager2!.delegate = self
        bluetoothManager2!.connectPeripheral(peripheral: aPeripheral)
    //MARK: - CBCentralManagerDelgate
    func centralManagerDidUpdateState(_ central: CBCentralManager) {
        guard central.state == .poweredOn else {
            print("Bluetooth is porewed off")
            return
        let connectedPeripherals = self.getConnectedPeripherals()
        var newScannedPeripherals: [NORScannedPeripheral] = []
        connectedPeripherals.forEach { (connectedPeripheral: CBPeripheral) in
            let connected = connectedPeripheral.state == .connected
            let scannedPeripheral = NORScannedPeripheral(withPeripheral: connectedPeripheral, andIsConnected: connected )
            newScannedPeripherals.append(scannedPeripheral)
        peripherals = newScannedPeripherals
        let success = self.scanForPeripherals(true)
        if !success {
    func centralManager(_ central: CBCentralManager, didDiscover peripheral: CBPeripheral, advertisementData: [String : Any], rssi RSSI: NSNumber) {
        // Scanner uses other queue to send events. We must edit UI in the main queue
        DispatchQueue.main.async(execute: {
            var sensor = NORScannedPeripheral(withPeripheral: peripheral, andRSSI: RSSI.int32Value, andIsConnected: false)
            if ((self.peripherals.contains(sensor)) == false) {
                self.peripherals.append(sensor)
            }else{
                sensor = self.peripherals[self.peripherals.index(of: sensor)!]
                sensor.RSSI = RSSI.int32Value
Although, I don't get an error and the connection is done, I don't receive the sensor values, as obviously I did something wrong. Do you have any idea? To get it run I have to connect to the UART part of the nRF Toolbox app, then manually type in "h" and "r" and then the sensor data re read out.
Thank you very much!
  • It's quite tricky to find out what went wrong here as we don't know how your peripheral works exactly, but the easiest way is to compile nRF Toolbox on your computer, and have a breakpoint at the point where we send the data to the characteristic, and compare the value of the `NSData` object being sent to the value your app is sending, this will show us at least if you're sending the correct data or not.
    Another thing to look out for is that you've enabled notification on the characteristic too so you'll be able to receive data. maybe you've forgotten that ?
