sdk15.0.0-》nrfx_wdt.c
The set values “nrfx_wdt_config_t”are different from the register values“NRF_WDT->CRV”
timeout [s] = ( CRV + 1 ) / 32768
Not sure I understand what the questions is, but it's not possible to re-configure the WDT after you have started it. In that case you wait for it to time out. Also, the NRFX_WDT_CONFIG_RELOAD_VALUE corresponds to the WD timeout in milliseconds.
Hello,Vidar Berg,
If i want to change the timeout time in WD in bootloader, NRFX_WDT_CONFIG_RELOAD_VALUE in switch file should i change ?
Hello,Vidar Berg,
If i want to change the timeout time in WD in bootloader, NRFX_WDT_CONFIG_RELOAD_VALUE in which file should i change ?
NRFX_WDT_CONFIG_RELOAD_VALUE is defined in sdk_config.h
