Hello I need to use proprietary_rf need technical support
你好 我现在有个需求
1 实现几十米的距离传输
2 一个数据广播发送机 8个数据接收机同时同步处理接收到的数据
3 发送机发送每秒10Kbyte数据给8个接收机同时处理、
4 我现在用 proprietary_rf\esb_ptx 与 proprietary_rf\esb_prx 1个机一个广播机 一个接收机
测试可以满足我的需求!但是这个例程可以实现1广播机8个接收机吗?还有proprietary_rf 里面的这些例程
怎么进行遇到干扰调整频道?
谢谢
Hello I have a need now
1 Achieve tens of meters of distance transmission
2 Data Broadcast Transmitter 8 Data Receivers Simultaneously Process Received Data
3 The transmitter sends 10Kbytes of data per second to 8 receivers for simultaneous processing.
4 I now use proprietary_rf\esb_ptx and proprietary_rf\esb_prx 1 machine with one broadcaster and one receiver
Test to meet my needs! But can this routine implement 1 broadcaster 8 receivers? There are also these routines inside the proprietary_rf
How to perform interference adjustment channel?
Thank you
