thank you very much But examples\proprietary_rf\esb_prx routines I still have two problems
你好 很感谢你们的协助 我的一个难题解决了
但是 我现在还有两个难题
我需要知道,
接收机和发射机之间通信时候 ,
怎么知道受到干扰影响?
需要更换频道?
怎么操作更换频道?
我现在是 一个广播机 一个接收机介绍情况
传输数据有时候会出现异常,
用手摸一下接收机的天线数据接收就回复正常
这个可能是什么问题?
非常感谢
Hello Thank you very much for your help. One of my problems was solved.
But I still have two problems
one
I need to know,
When communicating between the receiver and the transmitter,
How do you know that you are affected by interference?
Need to change channels?
How to change the channel?
two
I am now a broadcaster and a receiver.
Sometimes the transmission of data may be abnormal.
Touching the antenna data of the receiver will return to normal
What may be the problem?
thank you very much
  • 很对不起 有个问题描述错误   纠正一下
    但是 我现在还有两个难题
    我需要知道,
    接收机和发射机之间通信时候 ,
    怎么知道受到干扰影响?
    需要更换频道?
    怎么操作更换频道?
    传输数据有时候会出现异常,
    用手摸一下接收机的 /****天线*****/ 晶振 数据接收就回复正常
    这个可能是什么问题?
    非常感谢
    I'm sorry. There is a problem description error. Correct it
    one
    I need to know,
    two
    Touching the  /******antenna****/   Crystal   data of the receiver will return to normal
    thank you very much
    但是 我现在还有两个难题
    我需要知道,
    接收机和发射机之间通信时候 ,
    怎么知道受到干扰影响?
    需要更换频道?
    怎么操作更换频道?
    传输数据有时候会出现异常,
    用手摸一下接收机的  晶振 数据接收就回复正常
    这个可能是什么问题?
    非常感谢
    one
    I need to know,
    two
    Touching the     Crystal   data of the receiver will return to normal
    thank you very much
  • Hello Please focus on supporting my first question. The second question can help solve it better. I will then sequence the observation and analysis!
