Sending PDF files through BLE_APP_UART
I am using ble_app_uart service in my application. I am trying to send files using teraterm tool. If I am sending .txt or .doc files there is no disconnection in the devices. But if I am sending PDF or PPT file there is a disconnection between central and peripheral device. Is there any issue in sending PDF files? Also I am seeing some data loss while sending .txt or  .doc files.
Need a urgent solution for this.
  • Hey Manigandan,
    I need some detail on your implementation and more importantly some debugging information(source code, logs, error info, sniffer logs, etc).
    I think the two symptoms, disconnections and data corruptions, might be unrelated.
    The BLE_APP_UART example is sends ASCII strings over BLE and it is completely agnostic to it's string content with one exception. From Handling data received over UART:
    "The implementation of the example requires the newline character to be '\n'. Some terminals use different characters to trigger a newline, for example '\r'. Therefore, you might need to configure your terminal to interpret only '\n' as a newline."
    The reason why the doc and txt files have less corruption might be because they use less special characters or '\r' as newlines, or something in that direction.
    Cheers,
    Håkon.
  • Find the code in the attached file
    /* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <stdbool.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "nrf_uarte.h"
    #include "bsp.h"
    #include "app_fifo.h"
    #include "bsp_btn_ble.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #define EVENT_SIZE 20
    #define QUEUE_SIZE 5
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define DEVICE_NAME                     "BLE_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      0                                        /**< The advertising timeout (in units of seconds). */
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               7.5 //MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               7.5 //MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(7500, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define MAX_PKT_SIZE                    20
    #define MAX_SIZE                        1024                                        /** < Maximum no.of bytes in 2kB Memory. */
    static uint32_t baud_rate=UART_BAUDRATE_BAUDRATE_Baud115200;
    static void uart_init(void);
    typedef struct _my_queue
           int         head;
           int         tail;
           int         count;
           unsigned char  buffer[MAX_SIZE];
       } MY_QUEUE;
    /* Queue implementation */
    #define StructQueuePeekTail(q,N) ( ((q)->tail < (N-1))         ?  \
                                         &(q)->buffer[(q)->tail+1] :  \
                                         &(q)->buffer[0]              )
    #define StructQueueIsFull(q,N) ( (q)->count >= N )
    #define StructQueueIsNotFull(q,N) ( (q)->count < N )
    #define StructQueueIsEmpty(q,N) ( (q)->count == 0 )
    #define StructQueueIsNotEmpty(q,N) ( (q)->count != 0 )
    #define StructQueueCount(q,N) ( (q)->count )
    #define StructQueueSpaceAvailable(c,q,N) ( ((q)->count + c) <= N )
    static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
    void start_timer(void);
    static uint8_t data_array[32];
    MY_QUEUE UartQueue;
    uint8_t received_pkts=0,intr_count=1,buff_over_wrt=0;
    static uint16_t bytereceivedCount ;
    void StructQueueInit(MY_QUEUE * q)
       (q)->head  = 0;                              //(  (q)->head  = (N), \
       (q)->tail  = 0;                              //(q)->tail  = (N), \
       (q)->count = 0;                              //(q)->count =  0   )
    void StructQueueAdd(MY_QUEUE * q, uint8_t inByte)
      (q)->count++;
      if((q)->head < (MAX_SIZE-1))            //( ((q)->head < (MAX_SIZE-1)) ?
        (q)->head++  ;                        //((q)->head++)     :
        ((q)->head=0);                        //((q)->head=0)     ),
       if((q)->head == (q)->tail)
          printf("\r\nBuffer overrun !!\r\n");
      (q)->buffer[(q)->head]  = inByte;       //&(q)->buffer[(q)->head]
       bytereceivedCount++;
    int flag=0,                     /* */
        flag1=0;                    /* */
    void StructQueueRemove(MY_QUEUE * q, uint8_t * inByte)
      (q)->count--;
       *inByte = (q)->buffer[(q)->tail] ;
        if ((q)->tail < (MAX_SIZE-1))
         ((q)->tail++) ;
         (q)->tail=0;
      NRF_TIMER2->MODE = TIMER_MODE_MODE_Counter;              // Set the timer in Counter Mode
      NRF_TIMER2->TASKS_CLEAR = 1;                             // clear the task first to be usable for later
    	NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;		   //Set counter to 16 bit resolution
    	NRF_TIMER2->CC[0] = 7;                                   //Set value for TIMER2 compare register 0
    	NRF_TIMER2->CC[1] = 0;                                   //Set value for TIMER2 compare register 1
      // Enable interrupt on Timer 2, both for CC[0] and CC[1] compare match events
    	NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos) | (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
      NVIC_EnableIRQ(TIMER2_IRQn);
      NRF_TIMER2->TASKS_START = 1;               // Start TIMER2
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_nus    Nordic UART Service structure.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
        char data[10];
    	  uint32_t i;
        for (i = 0; i < length; i++)
            while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    			  data[i]=p_data[i];
        while(app_uart_put('\n') != NRF_SUCCESS);
    		// Added- For changing the baud rate dynamically
    		if(strstr(data,"BAUD9600")!=NULL)
    			app_uart_close();
    			baud_rate= UART_BAUDRATE_BAUDRATE_Baud9600;
    			uart_init();
    		if(strstr(data,"BAUD57600")!=NULL)
    			app_uart_close();
    			baud_rate= UART_BAUDRATE_BAUDRATE_Baud57600;
    			uart_init();
    		if(strstr(data,"BAUD115200")!=NULL)
    			app_uart_close();
    			baud_rate= UART_BAUDRATE_BAUDRATE_Baud115200;
    			uart_init();
    		if(strstr(data,"BAUD38400")!=NULL)
    			app_uart_close();
    			baud_rate= UART_BAUDRATE_BAUDRATE_Baud38400;
    			uart_init();
    		if(strstr(data,"BAUD14400")!=NULL)
    			app_uart_close();
    			baud_rate= UART_BAUDRATE_BAUDRATE_Baud14400;
    			uart_init();
    		if(strstr(data,"BAUD19200")!=NULL)
    			app_uart_close();
    			baud_rate= UART_BAUDRATE_BAUDRATE_Baud19200;
    			uart_init();
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
        if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    /**@brief Function for the application's SoftDevice event handler.
     * @param[in] p_ble_evt SoftDevice event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t                         err_code;
            case BLE_GAP_EVT_CONNECTED:
    						gap_params_init();
    						//uart_init();
                // Pairing not supported
                // No implementation needed.
    /**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
     *        event handler.
     * @details This function is called from the SoftDevice event interrupt handler after a
     *          SoftDevice event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
        ble_advertising_on_ble_evt(p_ble_evt);
        bsp_btn_ble_on_ble_evt(p_ble_evt);
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
                err_code = ble_advertising_restart_without_whitelist();
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
     *          @ref NUS_MAX_DATA_LENGTH.
    /**@snippet [Handling the data received over UART] */
        uint8_t   tempByte;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
               app_uart_get(&tempByte);
               StructQueueAdd(&UartQueue,tempByte);
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
        const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_DISABLED,
            false,
            baud_rate //Used static variable for configuring baud rate dynamically
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOW,
                           err_code);
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scanrsp;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        ble_adv_modes_config_t options = {0};
        options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    /**@brief Function for placing the application in low power state while waiting for events.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    /**@brief Application main function.
        uint32_t err_code;
        bool erase_bonds;
      	uint8_t index=0;
        uint16_t  icounter =0;
        // Initialize.
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
        uart_init();
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
        StructQueueInit (&UartQueue);
    	  printf("\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
        start_timer();
        nrf_delay_ms(1000);
        // Enter main loop.
        	for (;;)
           icounter++;
    			 //printf("\r\n Count %u\r\n",icounter);
    			 if(( icounter > 10000))
               err_code = ble_nus_string_send(&m_nus, data_array,index);
               index = 0;
               icounter = 0;
               // printf("\r\n 2 byteCount %u\r\n",bytereceivedCount);
    			   while(UartQueue.count >0)
              StructQueueRemove(&UartQueue,&data_array[index++]);
             if( index > 16)
               //printf("\r\n 1 index %u\r\n",index);
               index = 0;
               icounter = 0;
             power_manage();
  • Use our macro for setting the minimum and maximum connection interval. As of now you are assigning the value 7.5 to an uint16_t which makes no sense.
    You should set:
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL              MSEC_TO_UNITS(75, UNIT_1_25_MS)
    Use these settings before you start to optimize you latency.
    I will also recommend using UARTE with flow control. Then you'll get an event when the UART transmission is complete, instead of checking every receive byte for a newline.
