SAADC Always busy, error 17. SDK15
Hello DevZone,
I know that the subject has already be treat but in the others posts people seems to say that the error comes from the double buffering.
But in my case, I have no double buffering active. And I try to use the following function :
err_code = nrfx_saadc_sample_convert(0, ADC_value);
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf_adc_example main.c
 * @ingroup nrf_adc_example
 * @brief ADC Example Application main file.
 * This file contains the source code for a sample application using ADC.
 * @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_twi.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 1
volatile uint8_t state = 1;
static nrf_saadc_value_t     m_buffer_pool [SAMPLES_IN_BUFFER];//[2][SAMPLES_IN_BUFFER];
static uint32_t              m_adc_evt_counter;
static uint16_t ADC_value [1];
        ret_code_t err_code;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        flag = 1;
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
          ADC_value [0] = p_event->data.done.p_buffer[i];
          if (ADC_value [0] < 0)
            ADC_value [0] = 0;
          NRF_LOG_INFO("ADC value: %d", ADC_value[0]);
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_drv_saadc_config_t saadc_config;
    nrf_saadc_channel_config_t channel_config =
      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
    channel_config.reference =  NRF_SAADC_REFERENCE_INTERNAL;
    channel_config.gain =       SAADC_CH_CONFIG_GAIN_Gain1_4;
    channel_config.acq_time =   SAADC_CH_CONFIG_TACQ_3us;
    saadc_config.resolution =   SAADC_RESOLUTION_VAL_14bit;
    saadc_config.oversample =   NRF_SAADC_OVERSAMPLE_64X;//NRF_SAADC_OVERSAMPLE_DISABLED;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    saadc_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
    while (1)
Here's my code:
Anyone know, where does come from the error?
Sylvain.
