I use sprintf and then malloc stops allocating memory
Hi all. I fell into despair in an attempt to find a solution. If I do not use sprintf then everything works fine.
Before calling some_f, mqtt_put works without any grudges, but after that, malloc returns a null pointer.
This is just one example of using sprintf but further uses other options that also break malloc.
Further on the move all allocated memory is cleaned and released.
int some_f()
    SEGGER_RTT_TerminalOut(2, (char*)modem_data);
    uint8_t  amount = 0;
    char         sep[4]          = "\r\n";
    char         *array[32];
    char         *pstr;
    pstr = strtok((char*)modem_data, sep);
    while(pstr != NULL)
        array[amount] = pstr;
        amount++;
        pstr = strtok(NULL, sep);
    amount--;
    while(amount > 0)
        uint8_t sms_index = 0;
        sms_index = (uint8_t)hex_char(array[amount-2][7]);
        if(strstr(array[amount-2], "REC UNREAD") > 0)
            //char     _str[64];
            char         _sep[5]         = "\",\"";
            char         *_array[32];
            char         *_pstr;
            uint8_t  _amount = 0;
            char       sms_string[125];
            memset(sms_string, 0,   sizeof(sms_string));
            _pstr = strtok(array[amount-2], _sep);
            while(_pstr != NULL)
                _array[_amount] = _pstr;
                _amount++;
                _pstr = strtok(NULL, _sep);
            _amount--;
            SEGGER_RTT_printf(0, "amount = %d\r\n", amount);
            SEGGER_RTT_printf(0, "sms_index = %d\r\n", sms_index);
            SEGGER_RTT_printf(0, "%s\r\n", array[amount-2]);
            while(_amount)
                SEGGER_RTT_printf(0, "%s\r\n", _array[_amount]);
                _amount--;
            SEGGER_RTT_printf(0, "%s\r\n", array[amount-1]);
            sprintf(sms_string,"%s %s", _array[2], array[amount-1]);
            mqtt_put("sms", sms_string);
            memset(_array, 0,   sizeof(_array));
            amount-=2;
    memset(array, 0,    sizeof(array));
    at_write("+CMGDA=\"DEL READ\"");
    return 0;
void mqtt_put(char *topic_name_p, char *content_p)
    uint32_t err_code;
    char *content = (char*)malloc((strlen(content_p)+1) * sizeof(char));
    char *topic_name = (char*)malloc((strlen(topic_name_p)+1)* sizeof(char));
    strlcpy(content, content_p, strlen(content_p)+1);
    strlcpy(topic_name, topic_name_p, strlen(topic_name_p)+1);
    mqtt_fifo_t *mqtt_fifo = malloc(sizeof(mqtt_fifo_t));
    mqtt_fifo->content       = content;
    mqtt_fifo->topic_name  = topic_name;
    if(mqtt_fifo != NULL && mqtt_fifo->content !=NULL && mqtt_fifo->topic_name !=NULL)
        //working part
        SEGGER_RTT_SetTerminal(1);
        SEGGER_RTT_printf(0, "MALLOC ERR");
        SEGGER_RTT_SetTerminal(0);
