I have managed to get the SPIS block working using standard sets of read and transmit buffers. This all works.
I am now trying to use the ORC register to send a single byte to be transmitted rather than supplying a separate buffer, because in the main I wish to only transmit one byte and receive many. I don't mind if this byte is repeated either. The byte is a read command to an external SPI device, so doesn't need a long buffer.
If I set the NRF_SPIS1->MAXTX = 0, the ORC value does not appear on the SPI output, AND the status register does not show an over read. I get an all high signal.
If I set the NRF_SPIS1->MAXTX = 1, and set NRF_SPIS1->TXDPTR = &buffer, the first byte of the buffer is transmitted, but the ORC value still does not appear on the SPI output, BUT the status register does show an over read. The SPI transmits an all high signal when I have set the ORC value to something else. I also noticed that the AMOUNTTX is only equal to 1 when I know from my signal analyser that there has been 2 bytes transmitted, and AMOUNTRX = 2 as well.
Is this a known errata? or am I missing something
