nRF52832 "ble_peripheral->ble_app_uart" stops working
        I am trying to evaluate the "ble_app_uart" in the "nRF5_SDK" and I am using "DVK-BL652-SA-01" development board from LAIRD.
        The example works fine for a while. After some time, the application stops working. I can not even see the BLE device with my phone.
        What could be the problem ? Any idea ?
Best Regards
  • I simply made a counter in the main loop. every 1 second, I increment the counter and send it from uart. I see that when the counter reaches around 197, program stops working. I test it 10 times.
    Any idea ?
    So you are in a connection while this happens, is that right?
    Can you please try to define "DEBUG" in your preprocessor defines, and set a breakpoint in the error handler in app_error.c. Exactly what line that is on depends on the SDK version.
    Does the DVK from Laird come with an external LFXTAL, or does it use the RC Oscillator? If it uses the RC Oscillator, what settings have you used for it?
    Edvin
  • Hello Edvin,
          I am using the internal RC oscillator with the settings below.
    nrf_clock_lf_cfg_t const clock_lf_cfg =
            .source       = 0,
            .rc_ctiv      = 16,
            .rc_temp_ctiv = 2,
            .accuracy     = 1
    I will try to debug it.
  • Hello Edvin,
            I debug the code. When the code hits the "app_error_fault_handler" function, I get the register content below.
    <error> app: ERROR 8198 [Unknown error code] at E:\nRF5_SDK\examples\ble_peripheral\ble_app_uart\main.c:339
    PC at: 0x00033103
    <error> app: End of error report
    the "app_error_fault_handler" is called from the function above I think
    (dec) 8198 = 0x2006 = NRF_ERROR_SOC_POWER_OFF_SHOULD_NOT_RETURN.
    This happens because the function sd_power_system_off should not return. When you are in debug mode, it will actually be in a simulated system off state, and this function call may return, and it will return NRF_ERROR_SOC_POWER_OFF_SHOULD_NOT_RETURN.
    Please see the response in this case for some more detailed information.
    This leads back to my questions, what SDK and SoftDevice versions do you use? And are you in a connection when this happens, or are you advertising? I suspect this happens when you are advertising, and the advertising timer times out, calling the sd_power_system_off() function, turning off the chip to save power. Try to either extend your advertising timeout, APP_ADV_TIMEOUT_IN_SECONDS, or comment out the sd_power_system_off() call, or the sleep_mode_enter() call, which is the one calling sd_power_system_off(), and see if the issue disappears.
    Edvin
