GPIOTE and PPI to monitor radio state.
I am currently using nrf52840 for development, I am using 15.0.0 SDK which also contains zigbee SDK in it.
What I am planning to do is to add some codes within the zigbee example project, such as light_switch, and allow a GPIO pin (P1.03) to toggle its state (low->high->low) when zigbee is not doing Tx/Rx.
I wrote a function like below:
void config_ppi_and_gpiote()
NRF_P1->DIRSET |= 0x8;
    NRF_GPIOTE->CONFIG[3] = (GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos) |
                            (3 << GPIOTE_CONFIG_PSEL_Pos) |
                            (1 << GPIOTE_CONFIG_PORT_Pos) |
                            (GPIOTE_CONFIG_POLARITY_Toggle << GPIOTE_CONFIG_POLARITY_Pos) |
                            (GPIOTE_CONFIG_OUTINIT_Low << GPIOTE_CONFIG_OUTINIT_Pos);
    NRF_PPI->CH[7].EEP = NRF_RADIO->EVENTS_END;
    NRF_PPI->CH[7].TEP = NRF_GPIOTE->TASKS_OUT[3];
NRF_PPI->CHENSET |= (0x1) << 7;
In above code, it is to configure GPIO P1.03 and bind it with the EVENTS_END of Radio register. I am expecting to see GPIO P1.03 toggling while I am controlling the buttons on the light_switch device to on/off the LED of light_bulb device.
I used USBee to measure the state of P1.03 but it was not toggling at all – it remains low.
May I know if I did something wrong in the code above? Is it the right way to achieve what I am planning to do?
By the way, I simply built the light_switch project and didn’t run it with softDevice.
Thanks.
