I'm having problems to run the Loopback example in the Bluetooth Mesh SDK:
infocenter.nordicsemi.com/index.jsp
I'm receiving a timeout.
My setup is as follows:
- Ubuntu Bionic (18.04 LTS) 64-bit
- My user is added to the dialout group (for permissions to /dev/ttyACM0 etc)
- Python 3.6.5 (changed default /usr/bin/python symlink to not point to python 2) due to ninja's call to /usr/bin/python
- Using virtualenv with python 3 when calling interactive_pyaci
- nrf52832 dev kits
- Mesh SDK 2.0.1
- nRF5 SDK 15.0.0
- SEGGER JLink_V632c
It has worked on some occasions (after resetting/reprogramming), but often not.
However, nrfjprog seems to always recognize my dev board(s) (including indirectly, when programming using ninja), please see below:
(mesh) ...:~/projects/nrf5_sdk_for_mesh/build$ ninja flash_serial_nrf52832_xxAA_s132_6.0.0
[0/1] cd /home/daniel/projects/nrf5_sdk_for_mesh/build/examples/serial && /usr..._sdk_for_mesh/build/examples/serial/serial_nrf52832_xxAA_s132_6.0.0_merged.hex
Connected devices:
0: 682833172
Select one ('0'), several ('0, 1, 2') or all ('a') devices.
To quit, enter 'q': 0
# 682833172: Erasing device...
# 682833172: Programming /home/daniel/projects/nrf5_sdk_for_mesh/build/examples/serial/serial_nrf52832_xxAA_s132_6.0.0_merged.hex
# 682833172: Resetting...
(mesh) ...:~/projects/nrf5_sdk_for_mesh/build$ cd ../scripts/interactive_pyaci/
(mesh) ...:~/projects/nrf5_sdk_for_mesh/scripts/interactive_pyaci$ nrfjprog -i
682833172
(mesh) ...:~/projects/nrf5_sdk_for_mesh/scripts/interactive_pyaci$ nrfjprog -f NRF52 --reset
Applying system reset.
Run.
(mesh) ...:~/projects/nrf5_sdk_for_mesh/scripts/interactive_pyaci$ python interactive_pyaci.py -d /dev/ttyACM0 --no-logfile
To control your device, use d[x], where x is the device index.
Devices are indexed based on the order of the COM ports specified by the -d option.
The first device, d[0], can also be accessed using device.
Type d[x]. and hit tab to see the available methods.
Python 3.6.5 (default, Apr 1 2018, 05:46:30)
Type 'copyright', 'credits' or 'license' for more information
IPython 6.4.0 -- An enhanced Interactive Python. Type '?' for help.
In [1]: d[0].send(cmd.Echo("hello world"))
In [2]: 2018-05-15 16:17:07,547 - INFO - ttyACM0: cmd Echo, timeout waiting for event
Thank you!
