I try to make a simple project based on a "simple message model" (https://devzone.nordicsemi.com/f/nordic-q-a/29836/send-and-receive-a-string-via-access-layer) with Mesh SDK 2.0 and S132 ver. 6.0. I implemented logging on both sides (see attached file).
I was able to trace the problem to the following issue (check last 6 lines of the attached file): A number of configured devices is increased to 1 in provisioner_helper.c, however the main.c still reads the value as 0. How is this possible and how to fix this?
Server side:
<t: 0>, main.c, 343, ----- BLE Mesh Light Switch Server Demo ----- <t: 0>, mesh_softdevice_init.c, 107, Initializing SoftDevice... <t: 0>, mesh_softdevice_init.c, 72, Enabling BLE... <t: 2>, mesh_softdevice_init.c, 83, Ram base: 0x20006000 <t: 18>, mesh_softdevice_init.c, 99, sd_ble_enable: app_ram_base should be adjusted to 0x200032C8 <t: 532>, main.c, 317, Initializing and adding models <t: 5389>, main.c, 374, Device UUID : 0059FFFF000000001FBA307C8E0811BF <t: 531088>, main.c, 192, Successfully provisioned
Client & provisioner:
<t: 0>, mesh_softdevice_init.c, 107, Initializing SoftDevice... <t: 0>, mesh_softdevice_init.c, 72, Enabling BLE... <t: 2>, mesh_softdevice_init.c, 83, Ram base: 0x20006000 <t: 18>, mesh_softdevice_init.c, 99, sd_ble_enable: app_ram_base should be adjusted to 0x200032C8 <t: 531>, main.c, 508, Initializing and adding models <t: 543>, main.c, 600, Load cleared app data <t: 545>, main.c, 618, Configured & provisioned devices set to 0 <t: 549>, main.c, 722, Setup defaults: Adding keys, addresses, and bindings <t: 694>, provisioner_helper.c, 292, netkey_handle: 0 <t: 705>, main.c, 689, Waiting for Server node to be provisioned ... <t: 5556>, provisioner_helper.c, 217, Scanning For Unprovisioned Devices <t: 5559>, main.c, 762, <start> <t: 5671>, main.c, 652, Flash write complete <t: 5967>, main.c, 652, Flash write complete <t: 53994>, provisioner_helper.c, 125, UUID seen: 0059FFFF000000001FBA307C8E0811BF <t: 53997>, provisioner_helper.c, 77, Any UUID accepted <t: 54534>, provisioner_helper.c, 196, Provisioning link established <t: 67500>, provisioner_helper.c, 191, Static authentication data provided <t: 79053>, provisioner_helper.c, 160, Provisioning completed received <t: 79056>, provisioner_helper.c, 412, Provisioning complete. Adding address 0x0100. <t: 79062>, provisioner_helper.c, 311, Getting composition data <t: 83012>, provisioner_helper.c, 135, Local provisioning link closed: prov_state: 4 remaining retries: 2 <t: 135077>, provisioner_helper.c, 441, Config client event <t: 135080>, provisioner_helper.c, 454, Composition data: 0059000000000020000100000002010000020059000000 <t: 135084>, provisioner_helper.c, 318, Adding appkey <t: 138854>, provisioner_helper.c, 441, Config client event <t: 138857>, provisioner_helper.c, 326, Binding appkey to the Health model <t: 139686>, provisioner_helper.c, 441, Config client event <t: 139689>, provisioner_helper.c, 337, Binding appkey to the Simple On/Off model <t: 140614>, provisioner_helper.c, 441, Config client event <t: 140616>, provisioner_helper.c, 361, Setting publication address for the health server to 0x0001 <t: 143736>, provisioner_helper.c, 441, Config client event <t: 143738>, provisioner_helper.c, 382, Setting publication address for the On/Off server to 0x0001 <t: 147294>, provisioner_helper.c, 441, Config client event <t: 147297>, provisioner_helper.c, 390, Adding subscription <t: 149178>, provisioner_helper.c, 441, Config client event <t: 149517>, main.c, 170, 4.55 : Configuration of device 0 successful <t: 149521>, provisioner_helper.c, 509, Configured devices++, now 1 <t: 149524>, provisioner_helper.c, 217, Scanning For Unprovisioned Devices <t: 373040>, main.c, 170, 11.37 : Button 0 pressed <t: 373043>, main.c, 340, Configured devices = 0 <t: 373378>, main.c, 170, 11.38 : No devices provisioned
