USBD with FreeRTOS not work
Without FreeRTOS usbd working normaly with config:
#define NRF_SDH_DISPATCH_MODEL 0
#define APP_SCHEDULER_ENABLED 1
But with FreeRTOS need use
#define NRF_SDH_DISPATCH_MODEL 2
else it has errror
Error[Li006]: duplicate definitions for "SWI2_EGU2_IRQHandler"
How to solve this problem? What methods of USB need polling for working with FreeRTOS?
I'm use SDK15 and S140 v.6.0.0 Production
  • Hi, this is part from pre 15.1 repository.
    First of all you have to change nrf_drv_power.c file a little. We could not do it, but it helps to write clean code next:
    ret_code_t nrf_drv_power_init(nrf_drv_power_config_t const * p_config)
    #ifdef SOFTDEVICE_PRESENT
    +    if (m_initialized)
    +        return NRF_ERROR_MODULE_ALREADY_INITIALIZED;
        if (nrf_sdh_is_enabled())
    Then the main.c goes:
     * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup usbd_ble_uart_freertos_example main.c
     * @brief    USBD CDC ACM over BLE using FreeRTOS application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service
     * and USBD CDC ACM library and runs using FreeRTOS.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_freertos.h"
    #include "nrf_ble_gatt.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_usbd.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_drv_power.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "app_usbd_core.h"
    #include "app_usbd.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_cdc_acm.h"
    #include "app_usbd_serial_num.h"
    /* FreeRTOS related */
    #include "FreeRTOS.h"
    #include "task.h"
    #include "semphr.h"
     * The size of the stack for the Logger task (in 32-bit words).
     * Logger uses sprintf internally so it is a rather stack hungry process.
    #define LOGGER_STACK_SIZE 512
     * The size of the stack for the USB task (in 32-bit words).
    #define USBD_STACK_SIZE   256
     * The priority of the Logger task.
    #define LOGGER_PRIORITY 1
     * The priority of the USBD task.
    #define USBD_PRIORITY   2
     * The maximum delay inside the USB task to wait for an event.
    #define USB_THREAD_MAX_BLOCK_TIME portMAX_DELAY
    #define LED_BLE_NUS_CONN (BSP_BOARD_LED_0)
    #define LED_BLE_NUS_RX   (BSP_BOARD_LED_1)
    #define LED_CDC_ACM_CONN (BSP_BOARD_LED_2)
    #define LED_CDC_ACM_RX   (BSP_BOARD_LED_3)
    #define LED_BLINK_INTERVAL 800
    APP_TIMER_DEF(m_blink_ble);
    APP_TIMER_DEF(m_blink_cdc);
    static TaskHandle_t m_usbd_thread;        /**< USB stack thread. */
    #if NRF_LOG_ENABLED
    static TaskHandle_t m_logger_thread;      /**< Logger thread. */
     * @brief App timer handler for blinking the LEDs.
     * @param p_context LED to blink.
    void blink_handler(void * p_context)
        bsp_board_led_invert((uint32_t) p_context);
    #define ENDLINE_STRING "\r\n"
    // USB DEFINES START
    static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                        app_usbd_cdc_acm_user_event_t event);
    #define CDC_ACM_COMM_INTERFACE  0
    #define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
    #define CDC_ACM_DATA_INTERFACE  1
    #define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
    #define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
    static char m_cdc_data_array[BLE_NUS_MAX_DATA_LEN];
    /** @brief CDC_ACM class instance. */
    APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                                cdc_acm_user_ev_handler,
                                CDC_ACM_COMM_INTERFACE,
                                CDC_ACM_DATA_INTERFACE,
                                CDC_ACM_COMM_EPIN,
                                CDC_ACM_DATA_EPIN,
                                CDC_ACM_DATA_EPOUT,
                                APP_USBD_CDC_COMM_PROTOCOL_AT_V250);
    // USB DEFINES END
    // BLE DEFINES START
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define DEVICE_NAME                     "Nordic_USBD_BLE_UART"                      /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms). Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms). Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static char m_nus_data_array[BLE_NUS_MAX_DATA_LEN];
    // BLE DEFINES END
     * @brief Function for assert macro callback.
     *          how your product is supposed to react in case of an assert.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /** @brief Function for initializing the timer module. */
    static void timers_init(void)
        err_code = app_timer_create(&m_blink_ble, APP_TIMER_MODE_REPEATED, blink_handler);
        err_code = app_timer_create(&m_blink_cdc, APP_TIMER_MODE_REPEATED, blink_handler);
     * @brief Function for the GAP initialization.
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
     * @brief Function for handling the data from the Nordic UART Service.
     * @details This function processes the data received from the Nordic UART BLE Service and sends
     *          it to the USBD CDC ACM module.
     * @param[in] p_evt Nordic UART Service event.
            bsp_board_led_invert(LED_BLE_NUS_RX);
            NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on CDC ACM.");
            memcpy(m_nus_data_array, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            // Add endline characters
            uint16_t length = p_evt->params.rx_data.length;
            if (length + sizeof(ENDLINE_STRING) < BLE_NUS_MAX_DATA_LEN)
                memcpy(m_nus_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                length += sizeof(ENDLINE_STRING);
            // Send data through CDC ACM
            ret_code_t ret = app_usbd_cdc_acm_write(&m_app_cdc_acm,
                                                    m_nus_data_array,
                                                    length);
            if(ret != NRF_SUCCESS)
                NRF_LOG_INFO("CDC ACM unavailable, data received: %s", m_nus_data_array);
    /** @brief Function for initializing services that will be used by the application. */
        uint32_t       err_code;
        ble_nus_init_t nus_init;
     * @brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
    /** @brief Function for initializing the Connection Parameters module. */
        cp_init.disconnect_on_fail             = true;
        cp_init.evt_handler                    = NULL;
     * @brief Function for putting the chip into sleep mode.
     * @note This function does not return.
        // Prepare wakeup buttons.
    /**@brief Function for starting advertising. */
    static void advertising_start(void * p_context)
        UNUSED_PARAMETER(p_context);
     * @brief Function for handling advertising events.
     * @details This function is called for advertising events which are passed to the application.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                err_code = app_timer_start(m_blink_ble,
                                           APP_TIMER_TICKS(LED_BLINK_INTERVAL),
                                           (void *) LED_BLE_NUS_CONN);
            case BLE_ADV_EVT_IDLE:
                NRF_LOG_INFO("Advertising timeout, restarting.")
                advertising_start(NULL);
     * @brief Function for handling BLE events.
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("BLE NUS connected");
                err_code = app_timer_stop(m_blink_ble);
                bsp_board_led_on(LED_BLE_NUS_CONN);
                NRF_LOG_INFO("BLE NUS disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported.
            case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
                ble_gap_data_length_params_t dl_params;
                // Clearing the struct will effectively set members to @ref BLE_GAP_DATA_LENGTH_AUTO.
                memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
                err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
     * @brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /** @brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /** @brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
     * @brief Function for handling events from the BSP module.
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
    /** @brief Function for initializing the Advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    /** @brief Function for initializing buttons and LEDs. */
    static void buttons_leds_init(void)
        uint32_t err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    /** @brief Function for initializing the nrf_log module. */
    static void log_init(void)
    // USB CODE START
    static bool m_usb_connected = false;
    /** @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t */
        app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
        switch (event)
            case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
                /*Set up the first transfer*/
                ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                       m_cdc_data_array,
                                                       1);
                UNUSED_VARIABLE(ret);
                ret = app_timer_stop(m_blink_cdc);
                APP_ERROR_CHECK(ret);
                bsp_board_led_on(LED_CDC_ACM_CONN);
                NRF_LOG_INFO("CDC ACM port opened");
            case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
                NRF_LOG_INFO("CDC ACM port closed");
                if (m_usb_connected)
                    ret_code_t ret = app_timer_start(m_blink_cdc,
                                                     (void *) LED_CDC_ACM_CONN);
            case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
                ret_code_t ret;
                static uint8_t index = 0;
                index++;
                do
                    if ((m_cdc_data_array[index - 1] == '\r') || (index >= (m_ble_nus_max_data_len)))
                        bsp_board_led_invert(LED_CDC_ACM_RX);
                        NRF_LOG_HEXDUMP_DEBUG(m_cdc_data_array, index);
                        do
                                memcpy(m_cdc_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                            ret = ble_nus_data_send(&m_nus,
                                                    (uint8_t *) m_cdc_data_array,
                                                    &length,
                                                    m_conn_handle);
                            if (ret == NRF_ERROR_NOT_FOUND)
                                NRF_LOG_INFO("BLE NUS unavailable, data received: %s", m_cdc_data_array);
                            if (ret == NRF_ERROR_RESOURCES)
                                NRF_LOG_ERROR("BLE NUS Too many notifications queued.");
                            if ((ret != NRF_ERROR_INVALID_STATE) && (ret != NRF_ERROR_BUSY))
                        while (ret == NRF_ERROR_BUSY);
                        index = 0;
                    /*Get amount of data transferred*/
                    size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                    NRF_LOG_DEBUG("RX: size: %lu char: %c", size, m_cdc_data_array[index - 1]);
                    /* Fetch data until internal buffer is empty */
                                                &m_cdc_data_array[index],
                                                1);
                    if (ret == NRF_SUCCESS)
                        index++;
                while (ret == NRF_SUCCESS);
    static void usbd_user_ev_handler(app_usbd_event_type_t event)
        switch (event)
            case APP_USBD_EVT_DRV_SUSPEND:
            case APP_USBD_EVT_DRV_RESUME:
            case APP_USBD_EVT_STARTED:
            case APP_USBD_EVT_STOPPED:
                app_usbd_disable();
            case APP_USBD_EVT_POWER_DETECTED:
                NRF_LOG_INFO("USB power detected");
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                NRF_LOG_INFO("USB power removed");
                ret_code_t err_code = app_timer_stop(m_blink_cdc);
                bsp_board_led_off(LED_CDC_ACM_CONN);
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                NRF_LOG_INFO("USB ready");
                ret_code_t err_code = app_timer_start(m_blink_cdc,
                m_usb_connected = true;
                app_usbd_start();
    void usb_new_event_isr_handler(app_usbd_internal_evt_t const * const p_event, bool queued)
        BaseType_t xHigherPriorityTaskWoken = pdFALSE;
        UNUSED_PARAMETER(p_event);
        UNUSED_PARAMETER(queued);
        ASSERT(m_usbd_thread != NULL);
        /* Release the semaphore */
        vTaskNotifyGiveFromISR(m_usbd_thread, &xHigherPriorityTaskWoken);
        portYIELD_FROM_ISR(xHigherPriorityTaskWoken);
    static void usbd_thread(void * arg)
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_isr_handler = usb_new_event_isr_handler,
            .ev_state_proc  = usbd_user_ev_handler
        UNUSED_PARAMETER(arg);
        ret = app_usbd_init(&usbd_config);
        app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
        ret = app_usbd_class_append(class_cdc_acm);
        ret = app_usbd_power_events_enable();
        // Set the first event to make sure that USB queue is processed after it is started
        UNUSED_RETURN_VALUE(xTaskNotifyGive(xTaskGetCurrentTaskHandle()));
        // Enter main loop.
        for (;;)
            /* Waiting for event */
            UNUSED_RETURN_VALUE(ulTaskNotifyTake(pdTRUE, USB_THREAD_MAX_BLOCK_TIME));
            while (app_usbd_event_queue_process())
                /* Nothing to do */
    // USB CODE END
    #if NRF_LOG_ENABLED
    /**@brief Thread for handling the logger.
     * @details This thread is responsible for processing log entries if logs are deferred.
     *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
     * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
     *                    osThreadCreate() call to the thread.
    static void logger_thread(void * arg)
        while (1)
            NRF_LOG_FLUSH();
            vTaskSuspend(NULL); // Suspend myself
    #endif //NRF_LOG_ENABLED
    /**@brief A function which is hooked to idle task.
     * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
    void vApplicationIdleHook( void )
    #if NRF_LOG_ENABLED
         vTaskResume(m_logger_thread);
    /** @brief Application main function. */
        ret_code_t ret;
        // Initialize.
        log_init();
        timers_init();
        buttons_leds_init();
        app_usbd_serial_num_generate();
        ret = nrf_drv_power_init(NULL);
        ret = nrf_drv_clock_init();
    #if NRF_LOG_ENABLED
        // Start execution.
        if (pdPASS != xTaskCreate(logger_thread,
                                  "LOGGER",
                                  LOGGER_STACK_SIZE,
                                  NULL,
                                  LOGGER_PRIORITY,
                                  &m_logger_thread))
            APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
        if (pdPASS != xTaskCreate(usbd_thread,
                                  "USBD",
                                  USBD_STACK_SIZE,
                                  NULL,
                                  USBD_PRIORITY,
                                  &m_usbd_thread))
        NRF_LOG_INFO("USBD BLE UART example started.");
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Create a FreeRTOS task for the BLE stack.
        // The task will run advertising_start() before entering its loop.
        nrf_sdh_freertos_init(advertising_start, NULL);
        // Activate deep sleep mode.
        SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
        // Start FreeRTOS scheduler.
        vTaskStartScheduler();
        for (;;)
           APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
  • Thank you! I will check as soon as possible. Now I have USB working with RTOS, but does not work BLE, I hope an example of your code will help solve the problem
  • Please remember to set NRF_SDH_DISPATCH_MODEL to 2 in the sdk_config.h for the example above to work.
  • I checked the code, SoftDevice still does not work.
    The application crashes to err_code = nrf_sdh_ble_enable (& ram_start);
    where error code = 4
    NRF_LOG_WARNING("Change the RAM start location from 0x%x to 0x%x.",
    app_ram_start_link, *p_app_ram_start);
    I change ram start address from 0x20002A98 to 0x20002AB8 (*p_app_ram_start)
    and now it worked!!! =))
    Maybe someone will come in handy this solution.
    And thanks for the sample code! =))
