BLE Peirpheral UART with Timer Problem
        I'm using the "ble_app_uart" example without a problem. I need to add a timer to this example. For this purpose, I copied the content of the "peripheral_timer" example into "ble_app_uart" example. I configure the "sdk_config.h" content accordingly.
       The code is crushing in the following line of the "nrfx_timer_init" function.
     NRFX_ASSERT(p_instance->p_reg != NRF_TIMER0);
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    //Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
    err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
    nrf_drv_timer_extended_compare(
         &TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    nrf_drv_timer_enable(&TIMER_LED);
    // Enter main loop.
    for (;;)
        NRF_LOG_INFO("%d",i++);
        idle_state_handle();
    The reason for this is probably because you try to use TIMER0 for your TIMER_LED timer. The problem is that TIMER0 is also used by the SoftDevice, so you will get an assert, because the NRF_TIMER0 is already in use.
    In the top of the part from your peripheral_timer example, change:
    const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
    to
    const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1);
    And also, you need to enable TIMER1 in your sdk_config.h file.
    If you open the sdk_config.h file, you will probably find that TIMER0_ENABLED is defined to 1. Try to also change
    #define TIMER1_ENABLED 0
    to
    #define TIMER1_ENABLED 1
    Then your project should run with the softdevice using TIMER0, and the application timer using TIMER1.
    Edvin
  • By the way. The way that NRF_DRV_TIMER_INSTANCE() is implemented depends on what SDK you use, but it should be readable. You only need to change this to use TIMER1, and enable TIMER1 in sdk_config.h as I described in the previous post.
    Edvin
