Radio state notification
We can know the state of radio by checking NRF_RADIO->state register value, but is there any way that we can be "informed of" the state transitions of this register instead of polling it?
I tried to use GPIOTE+PPI to get the radio events but there is no proper event that can be used to exactly identify whether it's currently in TX (TXEN) or Rx (RXEN) state, the best we can know is to get it from TXREADY, RXREADY, DISABLED events.
TXREADY means it has ramped up in TX mode and get ready fo TX, it could be idle for a while before transferring a packet. Same as RXREADY.
Is there better suggestion on this?
I also used the light_switch example project of zigbee and GPIOTE+PPI to check the radio status, most of the time the radio are not in the disabled state, is it correct?
  • Is it possible to use/configure the PA/LNA feature within the zigbee SDK?
    From the document, it looks like the pins assigned to PA/LNA will be toggled before and after Tx/Rx, which is useful in my use case.
    I've found this function (PlatformFemSetConfigParams) in external/openthread/include/openthread/platform/platform-fem.h but there is some problem linking to its library.
  • Hey Crish,
    No, I'm afraid not.
    What kind of ZigBee device is it, Coordinator, Router, or End Device?
    What exactly is your problem?
    Cheers,
    Håkon.
