Issues with Buttonless DFU added to existing project
Hello:
We have a BLE project running on the BMD-300 from Rigado for which we want to add BLE DFU functionality. I am basing our development on the "ble_app_buttonless_dfu" project as well as the "secure_dfu_ble" for the bootloader. We are using NRF SDK 14.0.0 and IAR for our development. I have followed the great tutorial at "https://devzone.nordicsemi.com/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader" to generate the bootloader, bootloader options for application, merge bootloader+bootloader options, generate application,and load them up (also SD) with NRF GO. I set up the RTT logger on the main application.
I erase the chip, then I program the SD, then the bootloader, and then the application, and reset power. The unit always seems to be stuck in PC 0x13d6e of SoftDevice. Since it is a Hex I have no idea what it is doing there! I always have to attach to the running target and hit reset for the device to start performing properly.
I was having issues with the bootloader not setting the vector table correctly to the app, so when I initialized my other HW the interrupts were getting sent to the bootloader!
To remedy this, I added a call to "nrf_dfu_svci_vector_table_unset()" at the start of the program.
However, now I am getting an NRF_ERROR_INVALID_STATE error on "sd_softdevice_enable()" when I initialize the stack (on ble_stack_init() ).
How is the correct way to add the Buttonless DFU functionality to the device? Is there an order of function that I should follow? should the DFU initialization happen before the HW initialization so the code sets up the correct vector table?
If you could provide any guidance I would be very grateful! I have spend too much time on this.
Thanks!
