Hi, all,
I confuse with the function of shortcuts register while I'm using timer with two compare events in 52832.
In main() , I use API: nrfx_timer_extended_compare to configure two CC registers without enabling interrupt
nrf_drv_timer_config_t timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG; err_code = nrf_drv_timer_init(&TIMER_PWM, &timer_cfg, timer_pwm_event_handler); APP_ERROR_CHECK(err_code); nrfx_timer_extended_compare( &TIMER_PWM, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_ms_to_ticks(&TIMER_PWM, PWM0_CHANGE_INTERVAL), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false); nrfx_timer_extended_compare( &TIMER_PWM, NRF_TIMER_CC_CHANNEL1, nrf_drv_timer_ms_to_ticks(&TIMER_PWM, PWM1_CHANGE_INTERVAL), NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, false);
Then I want to enable CHANNEL0 interrupt while CHANNEL1 is always disabled and start timer
nrfx_timer_compare_int_disable(&TIMER_PWM, NRF_TIMER_CC_CHANNEL1);
nrfx_timer_compare_int_enable(&TIMER_PWM, NRF_TIMER_CC_CHANNEL0);
nrfx_timer_enable(&TIMER_PWM);
As a response, the timer doesn't work.
But what confused me, when I changed the codes and the timer works
nrf_timer_shorts_disable(TIMER_PWM.p_reg, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK);
nrf_timer_shorts_enable(TIMER_PWM.p_reg, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK);
Maybe I can't set COMPARE1_CLEAR even if COMPARE1 interrupt is not be enabled, but I don't find anything about this in nRF5 SDK v15 document.
Can someone provide me something about this?
Thank you!
Corey
