Button inturrpt works only once
We have added support to button click in our design but the intruppt only works once at the first time it is pressed.
What am I missing here? why is the button_evt_handler working only for the first button push?
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
//todo something
static void button_init(void)
ret_code_t err_code;
const uint8_t buttons_cnt = 1;
static app_button_cfg_t buttons_cfgs =
.pin_no = BUTTON_1,
.active_state = APP_BUTTON_ACTIVE_LOW,
.pull_cfg = NRF_GPIO_PIN_PULLUP,
.button_handler = button_evt_handler
err_code = app_button_init(&buttons_cfgs, buttons_cnt, APP_TIMER_TICKS(100));
err_code = app_button_enable();
int main(void){
button_init();
  • The link is about button push or realese.
    Im my case I care only about Push and the button_evt_handler is called only once in the first push and not working(no function call to button_evt_handler) in any of the follwoing push buttons
    Is there a command that needs to be registred after every usage of the button_evt_handler?
  • Try this example :SDK\examples\ble_peripheral\experimental_ble_app_blinky
    and edit the function like below (static void button_event_handler(uint8_t pin_no, uint8_t button_action))
            uint32_t err_code;
        switch (pin_no)
               	case LEDBUTTON_BUTTON_PIN:
                          switch (button_action)
                                 case APP_BUTTON_PUSH:
                                      // Do your task
                                case APP_BUTTON_RELEASE:
                                      // Do your task
                  APP_ERROR_HANDLER(pin_no);
  • i want to remove this button push (registration)..and want function "nrf_ble_es_on_start_connectable_advertising()"
    to be called directly...
    i tried commenting "app_button_init(&buttons_cfgs, buttons_cnt, APP_TIMER_TICKS(100));"
    and then called "nrf_ble_es_on_start_connectable_advertising()"   directly in button_init()..but eddystone is not advertising...i am using sdk15.3 and nrf52832...
    can you help me out
    Thank you
  • Hi.
    Could you create a new ticket for this issue?
    Since this question is not the same as the one asked in the start of this ticket, this ticket is also over one year old, and it will be hard for other community members to find it when they are searching.
    Andreas
