I'm usign nRF52832 with nRF5_SDK v15. I modified the example "ble_app_uart". I just remove the ble functions and added gpiote functions to wake up the MCU from sleep mode. I also add a line in the main to put the MCU in sleep mode.
My problem is that When BLE functions are in my code, My code works fine and MCU wakes up from sleep. However, When I remove the BLE functions in my code, the MCU never wakes up from sleep.
What is wrong with my code ? Can someone help ?
Best Regards
int main(void) { bool erase_bonds; // Initialize. uart_init(); log_init(); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true); config.pull = NRF_GPIO_PIN_PULLUP; err_code = nrf_drv_gpiote_in_init(3, &config, pin_event_handler); nrf_drv_gpiote_in_event_enable(3, true); // Enter main loop. for (;;) { nrf_delay_ms(1); x++; if(x>10000) sleep_mode_enter(); } }
static void sleep_mode_enter(void) { uint32_t err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Prepare wakeup buttons. //err_code = bsp_btn_ble_sleep_mode_prepare(); //APP_ERROR_CHECK(err_code); nrf_gpio_cfg_sense_set(3, NRF_GPIO_PIN_SENSE_LOW); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); }
