Dual Bank Bootloader Over ESB
I have two nrf52832 boards, both being developed with SDK v11 and the s132 soft device.
Board one is given commands over UART to communicate over ESB with board two. Board two also has serial communication with an FPGA that can be reprogrammed sucsessfully over ESB.
The goal is to be able to update the firmware on board two over ESB. Doing this will also reprogram the FPGA that currently boots from a file flashed along with the board two app via the "incbin" library.
Issues I'm having:
1. When trying to read and write to flash I discovered that DFU_BANK_1_REGION_START is in fact 0x918CB001. From my understanding this is the memory location of external RAM which is not attached and am not intending to attach. Also this not a multiple of four and is therefore not a valid boot address? The way the space for banks 0 and 1 are worked out seems to just be (BOOTLOADER_REGION_START - CODE_REGION_1_START)/2, leaves the available space around 1.75GB per bank for me, which is certainly not correct. I know i need to redefine these, but what is the best way to set the start and end position of both banks?
2. Getting the bootloader to validate the new image and swap it into bank 0 over ESB? I currently can't try this due to not being able to write into the right places in memory but any advice other than swapping over to BLE comms for bootloading or trying to change code for BLE comms with ESB protocols throughout the DFU example would be appreciated.
Thanks in advance
Jack
  • You can remove the softdevice if you don't plan to use BLE. But you still need the MBR to do the image replacing. What you are planing to do require good understanding on how the MBR works and assessment if a bootloader needed or not. I would suggest you to get familiar with how our bootloader work, how we replace application image and also replace the bootloader itself. How the bootloader is executed and the vector table is forwarded by the MBR.
    The start point of your application is defined in the .ld file, as in the blinky example :  FLASH (rx) : ORIGIN = 0x0, LENGTH = 0x80000 , start at address 0x00.
    The size of your application shows by the compiler after you build it. Or you can find the size using .map file, or convert to binary file.
  • Hello again, sorry for the late response I've been working on this among other things. So currently I've managed to get the boot commands to work over ESB as far as validating an image and booting from an address, in this case still just 0x00000000.
    I have code which will sucsessfully send a binary file and write it into a memory location of my choosing however the binary file produced by GCC is far too large.
    From what i understand and from looking at the information on the file in a binary/hex file interpreter, all of the information past  0x00004510 are just zeros. untill you hit the final address in my currently 256MB file 0x10001209, which simply contains 0xFFFFFFFF, which i assume is just storing the flash mask.
    My question now is, can i chop my binary file down to 0x00004510 and run it?
    Again, thanks in advance
    Jack
  • Hi Jack,
    I guess in your code you have some data to be written to UICR (0x10001209) ? If you do , would suggest you to split the hex file, so you have separate hex for the main application and separate hex for the UICR. Then you convert them to binary.
    If you keep them in one hex file, gcc has no other way of generating binary other than making that 256MB bin file (binary file has no address, to get to the UICR it has to add the 0xFFFFFFFF)
    In your DFU application, you then receive 2 files one to be written as application and one to be written to UICR
  • I'm currently trying to change the linker file to write the UCIR data right after my application then on start up have the app write the UCIR values to the correct address, is this a good approach? I'm thinking that this would streamline the updating process a bit more. My linker file and the start up code currently looks like this.
    /* Linker script to configure memory regions. */
    SEARCH_DIR(.)
    GROUP(-lgcc -lc -lnosys)
    MEMORY
      FLASH (rx) : ORIGIN = 0x00000, LENGTH = 0x80000
      UICR (rx) : ORIGIN = 0x10001000, LENGTH = 0x0FFFF000
      RAM (rwx) :  ORIGIN = 0x20000000, LENGTH = 0x10000
    SECTIONS
      .app 0x000000000 : { *(.app) _eapp = . ;}
      .muicr 0x1000120C :
      AT( ADDR (.app) + SIZEOF (.app) )
      { _uicr = . ;  *(.uicr);  _eucir = . ;  }
      .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
      } > RAM
    } INSERT AFTER .data;
    INCLUDE "nrf5x_common.ld"
      //save the UCIR address manully to reduce the size of the bin fin for each applcation
        extern char _eapp, _ucir, _eucir; //beginning of UCIR LMA, beginning of UCIR VMA, end of UCIR VMA
                    // __start_fs_data, //data start address
                    // __stop_fs_data;  //data end address
        //define pointer to the start of both the load and virtual memory addresses fo the UCIR data
        char *src = &_eapp;
        char *dst = &_ucir;
        //write the UCIR data across on boot, this should be indpendant of the start address of the application
        while(dst < &_eucir){
          *dst = *src;
          *src = 0xFF; //write flash mask to the temp storage address
          dst++;
          src++;
  • If you have the code to read the UICR and don't try to write to it on every boot then it's fine. We also do that with some of our code to enable errata fix or configure Reset pin, NFC pins.
    But I don't think you can write to flash by just assigning the value to the pointer. Please look for this line in system_nrf52.c to see how to do it
    #if defined (CONFIG_NFCT_PINS_AS_GPIOS)
    I'm not sure why you don't want to edit the hex file. The intel hex definition can be found here. You just need to edit the hex to split it into two.
    Another option if you don't want to edit the hex is to flash the hex to a chip, then try to read it out using nrfjprog, you can read the application part and the UICR part separately to have 2 hex files. Then you convert the hexes to binary files.
